3.2. 2017 exhaust gas temp fault
Will88
Will
Perth
Xls ford ranger
Mechanic
Hey all
I've got an issue on a 2017 DPF XLS ranger aus spec where my (bank 1 sensor 4) reads -40 degrees permanently I have changed the exhaust manifold sensor which I believe is sensor 4 with no difference. I have check the 5v supply to the sensor which is all good. When I unplug each of the other exhaust senors they drop off with OBD2 reader. Any help any advice you could give me would be awesome cheers in advance
colin39
Colin
Y-uk
3.2 ranger with issues
Mechanic believe it or not
Hey all
Did you ever resolve this as I have egt14 -40° and can only find 3 Inc the egrt (exhaust gas recirculation valve temperature sensor) that reads really high but it's brand new 🤷🏻
I do not have access to the 3.2 (ROW) Ranger manuals
Are you getting a code for it (EGRT 14)?
What are the other 3 sensors (Voltage Readings)?
If not coding anything for EGRT 14, then you need to verify that the 3.2 actually has one installed.
I have a feeling you have been bitten by the (PID) only - I have an issue
You have to take into account that you are using a Aftermarket scan software and it may display PIDs you do not even have installed.
The software program thinks its installed and will display a (DEFAULT) parameter such as:
(-40 C) or (6.55v) as it does not know the exact parameter.
So you may only have 3 sensors not 4.
colin39
Colin
Y-uk
It only has 3 sensors, it had a bad map I have rtnd it to stock with frds but I'm still getting this and no codes
Got a door code here , but I've now fixt that
And a heated screen code
colin39
Colin
Y-uk
I did have this lot before I rtnd it to stock
Start the truck and close all doors;
Perform a BCM & FCIM - Self Test (Reset) and see if the remaining codes clear
The BCM code is for (Passive Entry) Door Handle
The FCIM code - I do not see in the manuals so (?)
There are times when running self tests etc - The Truck must be in a normal configuration or when it runs a self-test it may trigger a false fault code as it cannot see the proper feedback from the self test results.
Plus, if you have had the truck using only battery power for a long period, the BCM may have load shed the RH door passive entry
colin39
Colin
Y-uk
Door code has gone , I turned passive entry off as I don't like it use it.
It's just the throttle cut/shudder/bucking or surg that's causing the issue and no code
