Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
If anyone happens to be in the market for King rears we have a few of these in stock ready to ship.
Message me for forum pricing.
2019-2022 Ford Ranger 4WD King OEM Performance Series 2.5 Adjustable Piggyback Rear Shocks in a Pair 25001-387A
Highlights:
King is one of the most famous names in off-road suspension and racing, so you know that you can trust their 2.5 Piggyback rear shocks for the 2019-2022 Ford Ranger to provide a huge improvement in performance over stock and allow you to take your aggressive off-road Ranger build just about anywhere you need. These powerful shocks feature large shafts and pistons that are combined with a high-quality shock design and piggyback reservoirs to provide increased travel, improved rebound, better compression, and greatly reduced fade over your truck's factory rear shocks all while bolting right on in their place. On top of their excellent off-road performance, this pair of rear shocks is backed by King's legendary commitment to quality, and the shocks won't let you or your Ranger down, no matter where you end up taking them. The piggyback reservoirs are even fitted with a King compression adjuster that allows you to tune your Ranger's ride and performance.
High-Quality Shock Bodies with Anodized Aluminum Reservoirs
King combines larger shock bodies with a race-inspired internal design and then tops everything off with a piggyback reservoir so that you Ranger gets a big bump in overall suspension performance. The rear shocks each feature 2.5" diameter shock bodies with large-diameter shafts and a heat-treated 6061-T6 aluminum shaft that helps maintain excellent ride quality while producing extra performance. The shocks are each made out of high-quality aluminum with an anodized finish and feature high-strength rod ends with spherical bearings that help minimize deflection. The reservoir of each shock is made from hard anodized 6063 aluminum alloy which greatly improves heat dissipation over internal reservoir shocks while resisting corrosion in practically any climate or application. This shock can additionally handle up to 2" of rear ride height over stock for the best performance. The compression adjuster is located on the piggyback reservoirs and works by adjusting oil flow from the reservoir to the main shock body.
Fitment: 2019-2022 Ford Ranger 4WD.
Returns: King does not accept returns on any of their parts, except in the case of manufacturing defects. Call Stage 3 directly at 623-434-5277 for more information.
RWD/2WD Ranger Fitment: this shock will not fit an RWD/2WD Ranger out of the box, due to slight differences in the RWD truck's lower shock mounts. Replacing or boring out the included bushing sleeve will allow fitment on an RWD/2WD Ranger.
Highlights:
- Huge improvement in performance and handling
- Can handle up to 2" of rear ride height over stock
- 2.5" diameter shock with piggyback reservoir
- Adjustable compression for tuning your ride
- High-quality parts and components
- Direct bolt-on replacements for stock
