Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
2019-2022 Ford Ranger Hellwig Adjustable Rate Rear Sway Bar 7778
Installation Video
Highlights:
For a midsize truck, the 2019-2022 Ford Ranger does a decent job of towing and hauling. Even if you're not near your GVWR or GCWR, you may get pretty serious instability and handling issues. Stock sway bars are not sufficient for modern load and tow demands. Hellwig's Rear Adjustable Rate Sway Bar can correct this fault easily. The sway bar offers big-time handling upgrade, especially when you're towing and hauling heavy loads. The Hellwig Sway Bar improves lateral stability and helps keep your axle and wheels planted during hard turns, making your towing experience much less hair-raising. Hellwig's Sway Bar bolts right onto your Ranger, making it a hassle-free way to win back stability and handling.
Solid, Chomoly Steel Sway Bar with Adjustable Roll Settings
Hellwig's Sway Bar is built incredibly strong and has an adjustable design so that you can find your perfect level of performance and handling. Hellwig's Ranger sway bars are made of heat-treated, chromoly steel alloy with a solid construction that helps distribute load between your truck's rear wheels. The sway bar has three mounting holes that allow for adjustments in roll stiffness so that you can set the bar perfectly for your intended application. Each Hellwig sway bar come with all the hardware you need for installation, and each sway bar was carefully designed to bolt right up to your Ranger without any drilling or modifications. Hellwig even backs their sway bar with a limited lifetime warranty.
Fitment: 2019-2022 Ford Ranger.
Differential Cover Fitment: this sway bar may not clear oversized aftermarket differential covers.
Installation Video
Highlights:
- Improves handling and rear stability
- Excellent towing and hauling upgrade
- Solid sway bar with adjustable design
- Chromoly steel construction
- Includes hardware for bolt-on install
- Backed by a limited lifetime warranty
