Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
Bilstein 5100 fronts and rears are in stock, available as front or rear or packaged together.
2019-2022 Ford Ranger Bilstein B8 5100 Front Shocks in a Pair 24-294218
Highlights:
The 2019-2022 Ford Ranger should not be trusted to handle the toughest of off-road trails. If you need something with better performance and up to 2.5" of height, a pair of Bilstein B8 5100 front shocks will not disappoint you. These front shocks are the perfect replacements for the stock leveling components and come backed by Bilstein's legendary quality and performance. The Bilstein B8 5100 shocks are built from scratch to offer your Ranger a very defined experience. An adjustable height from 0 to 2.5" allows you to raise the Ranger to your liking and fit larger off-road tires. This increased height and potential new tires help protect your Ranger from off-road obstacles and creates a better driving experience out in the dirt. The specialized valving, high-quality piston and other great components of these shocks provide excellent off-road performance, increased wheel travel, and better handling! Features Better Components & Installs Easily
The Bilstein Ranger 5100 front shocks replaces your stock OEM coilover suspension and use the best components for excellence. The 5100 rear shocks are built around a monotube, nitrogen gas-charged design for fade-free performance. Each shock uses self-adjusting deflective disc valving, which adapts to different road conditions and provides excellent response in almost any application. The shock's digressive piston adapts to changing road conditions. The smooth body of each shock is made out of heavy-duty steel and features a 46mm diameter build for a strong shock. Snap-in grooves allow you to make height adjustments between 0 and 2.5". A zinc-plated finish and a Triple-C coating adds a great look. When collapsed, the shock reaches 14.59" and 19.26" when fully extended. Bilstein includes all necessary installation instruction and hardware.
Fitment: 2019-2022 Ford Ranger
Kit Contents: This kit includes two front shocks.
Highlights:
- Adjustable front lifted height up to 2.5"
- Increases wheel travel
- Allows for larger wheel fitment
- Consistent, fade-free performance in all conditions
- 46mm monotube design
- Made in the USA
