Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
Bilstein 5100 rear shocks are back in stock! These are now in stock and ready to ship as rears only or part of our 4corner package.
(web inventory is not updated)
2019-2022 Ford Ranger Bilstein B8 5100 Rear Shock (0-1" Lift) 24-294225
Highlights:
The 2019-2022 Ford Ranger should not be trusted to handle the toughest of off-road trails. If you need something with better performance and the capability to handle 1" of rear height, the Bilstein B8 5100 rear shock will not disappoint you. These rear shocks are the perfect replacements for the stock shocks and come backed by Bilstein's legendary quality and performance. The Bilstein B8 5100 shocks are built from scratch to offer your Ranger a very defined experience. The specialized valving and high-quality piston of these shocks provide excellent off-road performance, better comfort on uneven terrain, improved towing control, and a fade free performance! Features Better Components & Installs Easily
The Bilstein Ranger 5100 shocks bolt-on in place of your factory rear shocks and use the best components for excellence. The 5100 rear shocks are built around a monotube, nitrogen gas-charged design for fade-free performance. Each shock uses self-adjusting deflective disc valving, which adapts to different road conditions and provides excellent response in almost any application. The shock's digressive piston adapts to changing road conditions. The smooth body of each shock is made out of heavy-duty steel and features a 46mm diameter build for a strong shock. A zinc-plated finish and a Triple-C coating adds a great look. When collapsed, the shock reaches 15.55" and 24.71" when fully extended. Bilstein includes all necessary installation instruction and hardware.
Fitment: 2019-2022 Ford Ranger
Single Shock Only: This listing only comes with one shock. Two will be needed for fitment to your rear suspension.
Highlights:
- For rear lifted height up to 1"
- Increases suspension travel
- Consistent, fade-free performance in all conditions
- 46mm monotube design
- Includes installation instructions and hardware
- Easy, direct-fit installation
- Made in the USA
