2019-2021 Ford Ranger Kicker KS Series Drop-In Plug-and-Play Door Speaker Package
Status
Not open for further replies.
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
2019-2021 Ford Ranger Kicker KS Series Drop-In Plug-and-Play Door Speaker Package KICK1920RNGRPPKIT1
Shoot me a message if anyone is looking for some upgraded tunes!
Highlights:
  • More range, volume, and clarity
  • Includes plug-and-play wiring and no-drill brackets
  • Full set of four 6.5" KS-Series Door Speakers
  • Hassle-free installation and wiring
  • Works with all head units and audio options
Huge Improvement in Audio Quality and Range in a Hassle-Free Package
It's no secret that the factory speakers on the 2019-2021 Ford Ranger isn't that great. Even the speakers included in the premium Sony Audio and B&O Audio Packages aren't much to write home about. That's why we at Stage 3 put together this complete drop-in, plug-and-play Kicker Door Speaker Upgrade Package. This awesome kit comes with a set of four Kicker 6.5" KS-Series Speakers, Metra Adapter Rings for fitting in the Ranger's "unique" mounts in the front and rear doors, as well as Metra plug-ang-play wiring harnesses that let you plug the Kicker speakers right into your truck's stock wiring. The KS Series Speakers provide an excellent increase in sound quality, depth, and range while the additional Metra hardware allows for a hassle-free installation with no drilling and no splicing. This awesome kit makes it a breeze to get significantly better audio out of your Ranger without a bunch of hassles. Set of Four 6.5" Kicker KS-Series Speakers with Install and Wiring Adapters
The Kicker KS-Series Speakers feature a high-quality design and are carefully constructed to maximize range and sound quality in a package that replaces your factory speakers. Each speaker is made with extremely stiff polypropylene cones with durable rubber surrounds that allow the woofer to generate more bass response than your more basic factory speakers. The tweeters of each speaker have a dome-style design and are made using a silk material with neodymium magnets that all work together to generate clean, crisp highs with minimal levels of distortion, even at high volume. All four speakers come ready to be installed out of the box. The included ring and wiring adapters allow for an easy install of the speakers. making this package one of the most hassle-free audio upgrades on the market.
Kicker 6.5" Speaker Specs:
  • Woofer Size: 6-1/2"
  • Tweeter Size: 3/4"
  • Impedance: 4ohms
  • Peak Power: 200 watts
  • Continuous Power: 100 watts RMS
  • Sensitivity: 90dB
  • Frequency Response: 43-21k Hz
  • Top Mount Depth: 1-13/16"
  • Bottom Mount Depth: 2-3/16"
  • Tweeter Protrusion: 5/16"
the5Gmartian
Jesse
Washington, D.C.
2020 Ford Ranger Lariat FX4
U.S. Navy
Awesome! If you guys add a drop in sub to this kit it would sell like crazy! Could I get the forum pricing? Thank you!
HarryManback
New England
2021 Ranger XLT Tremor
Electrical Engineer
I don't know how Frank does it, but he had my order packaged up and a shipping label printed within 7 minutes of me placing my order. I can't wait to hear the difference, the stock speakers leave a lot to be desired.
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
Did you get these and install them? Curious on the sound.
Living The Dream
Same here.
Curious how much of an upgrade.
Also, do these retain the A-pillar tweeter?
HarryManback
New England
Electrical Engineer
Same here.
No a-pillar tweeters, just the 4 door speakers.
I got them last night, hoping to install them this weekend.
Living The Dream
I knew it didn't include new tweeters, just wondering if these remove the factory tweeters from the circuit or if they retain them.
HarryManback
New England
Electrical Engineer
I guess I don't understand. The factory tweeters are unrelated to these replacement speakers. There's no reason to remove the factory tweeter, and doing so would have an adverse affect on the height of the sound stage in the truck. These speakers just essentially add a bonus tweeter in each of the doors.
HarryManback
New England
Electrical Engineer
Installed them this weekend. Pretty straight forward process getting the door panels off. I do have two small concerns/issues that I didn't have time to properly remedy this weekend:
1. The front door panel/speaker grills interfere with the new speakers and the door panel doesn't sit flush, and I can't get the two clips to engage. I suspect it's just a minor clearance issue and it's not even noticeable unless you know to look for it.
2. I don't know how to wire the speakers without pinching the wires between the plastic bracket and the metal door. Long term I'm worried about vibration and may find a way to modify the plastic bracket so I can pass the wires through it instead of under it.
I took the opportunity to add some dynamat behind the speakers (will do more of the doors as time allows), and it sounds phenomenal. I had the volume up to 25 and I had no distortion or crackling what-so-ever. The only reason I turned it down was my ears were starting to hurt!
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
What system did you have? So your overall impression is….better sound quality?
Are there any coupons available?
HarryManback
New England
Electrical Engineer
I have just the standard Sync3 system (no B&O). Sound quality is definitely better. It could still be better yet with an improved amp for the speakers, but since I already have a subwoofer installed I don't see the need.
Status
