Wrench light on.
RangerBill
PA
Same code. P061B. Truck reports powertrain malfunction and pre-collision assist disabled.
Here is the shop manual description for P061B:
Gasoline Engines PCED
P061B - Internal Control Module Torque Calculation Performance
Description:
This DTC sets when a calculation error occurs in the PCM.​
Possible Causes:
  • Aftermarket performance products
  • Incorrect tire size
  • Incorrect axle ratio
  • Incorrect vehicle identification (VID) block programming
  • Module programming error
Diagnostic Aids:
Check for sensor and circuit related DTCs. Do not install a new electronic throttle body (ETB) for this DTC.
The presence of this DTC may indicate that the vehicle is operating in failure mode and may experience a loss of power.​
Application
Key On Engine Off
Key On Engine Running
Continuous Memory
All​
GO to Pinpoint Test QE .​
To rule out the Accelerator Pedal and Throttle Body (TPS)
Pull up Live Data - (KOEO) Key on engine off
Live Data:
The APP1 / APP2
TP1 / TP2
Slowly press the accelerator pedal down to the floor and slowly release it.
Ensure the PID readings remain steady and not glitching (jumping)
They should follow pedal movement and stay close to the readings, not jump out and then back.
Pay close attention to the (pedal position) for when you normally are experiencing the issue when driving, such as driving slowly through a parking lot (example)
and you can also try (Pausing) at spots and see if the PID remains steady.
You may try this with BOTH - Cold Engine and Hot Engine
As stated previously there are many factors than can trigger this code.
But these PID's are an easy visual look on how the APP / TPS sensors are electronically operating.
