Wheels.
Ranger Off Roading
Ray
2023 Ford Ranger Lariat Tremor
Was going to put 1 inch spacers on my 23 Tremor but now I might decide to go with aftermarket wheels. Thinking maybe the Fuel Rails 17×9 +1 or KD Offroad 0 offset. How far out would the tires stick out with a +1? Would 0 be similar to what's already on the truck?
Living The Dream
The stock wheels are +55mm offset so a 0 offset wheel will stick out 55mm more (a bit over 2 inches).
2 inches doesn't sound like a lot but it can lead to interference with the crash bars due to the wider turning arc of the front wheels.
Having a Tremor, you will probably be fine.
My wheels are +20 and I have Bilstein 5100 fronts set at 1.8 lift.
I experience no rubbing at all.
Ranger Off Roading
Ranger Off Roading
Ray
Cool! Thanks. Im running readylift leveling kit, top spacers only. 3/4 inch difference from the rear. Don't really want to stick out 2 inches, just 1 inch at the most and then go with 275/70/17 and hopefully clear the crash bars with no issues. Still considering using 1 inch wheel spacers on the factory wheels, if it will give me that aggressive look still. Choices 🤪
veedubtuner
Morgan
Tulsa, OK
2023 CG XLT Scab FX4 Ranger
VW Parts slinger
This website helps with fitment questions current/after and gives you visual difference as well.
https://www.willtheyfit.com
