What Size Wheel Spacer 1.5" or 2" To Get?
1medic
Ca. USA
2019 Ranger XLT 4x4 SuperCrew
If you running wheel spacers let me know what size (width) your running and post a pic(s). I'm looking at Bora and trying to figure out 1.5" or 2".
I'm running stock 17's and want a wider stance without having to change wheels.
Also this is not an invitation for a "wheel spacer vs no wheel space debate. If you have a negative opinion on them please keep it to yourself or another post. Thanks!
sbacpo
Claybuster
Just a data point on Bora. I ordered mine on 9/13 and they're on the FedEx truck for delivery today. Just to give a feel for lead time.
I'm only doing a .5" spacer. I just wanted a little more relief from the spindle. I'm not rubbing and probably won't rub but there ain't much gap in there.
FULLSCALE
Adam
Ontario, Canada
Are they a hubcentric spacer, and are the stock studs long enough for them?
sbacpo
Claybuster
Yes. You bolt the spacer to the hub using the stock studs and mount the wheel to the studs on the spacer.
FULLSCALE
Adam
Ontario, Canada
Okay thanks, I thought a 1/2" spacer would be too thin to do that. Do you have to shorten the factory studs or are there pockets in the wheel mounting surface that have room for them?
