What is this nut?!
TannerVoss1231
Tanner
Colorado, United States
2020 Ranger Lariat
Web Developer
After doing some lower control arm work I wanted to change the nut on the lower control arm ball joint (connects to steering knuckle)
I have been to the dealership 3 times and even pulled the nut off in the parking lot - they can't find the replacement. Shop guide instructs you to throw the old nut away when removed.
So far I believe I have tried the H2 and H4 nuts from their in-house schematic but one nut was actually for the upper ball joint and the other just had different shape and different thread pitch.
Can anyone help? Hoping Phil Shilke can pop in on this one.
2020 Lariat with steel knuckles
1FTER4FH7LLA79959
Don't know what thread it is, most likely metric, but it's called a Flange Nut.
TannerVoss1231
TannerVoss1231
Tanner
2020 Ranger Lariat
Web Developer
Aha, I will give them a call to see if they have that in stock. I was given W520214-S440 - had a different thread pitch. I am assuming he was unable to find it because some paint huffer labeled the correct nut as a Tie Rod nut instead of titling it a lower ball joint nut.
Jason B
2021 XL STX SE 4x2
machinist
What's crazy is that the title says Tie Rod Nut, but the description says Lower Ball Joint Nut.
Bob902
St. Louis
RETIRED!!!!
It's Ford. Wouldn't expect anything less
The description says it's for the "lower ball joint nut , right" , is the left one the same only a little lower?
Hay....if I can have a leftie and a rightie, why can't my Ranger ??? And, depending on the time of day, one can certainly be lower than the other !!!
NotBudule2
21 Ranger
I agree, but I get confused when looking in a mirror, I end up tugging on the wrong one trying to even them out... if I could still stand on my head, it would be easier to tell...maybe...
Thats your problem.....tugging !!!! Ya gotta twist, like threading the nuts on your Ranger.....rightie tightie, leftie loosey !!!
Just pick one to adjust and twist in the appropriate direction....
NotBudule2
21 Ranger
That would have been helpful info maybe 10 years ago, but I'm close to tucking them in my socks at this point, probably to late...
Yeah, been there done that, past that....now using a pull behind cart...keeps from getting all tangled up.....for awhile it was embarrassing, tripping over myself all the time...
