Various tapping sources for triggers.
RAYJAY
UNION DALE PA
2020 ranger pickup 2019 subaru
what quick connector are you using to tap into the high beam wire ?
RAYJAY
UNION DALE PA
I just picked the driver side bulb harness and did a waterproof splice for the trigger wire to the relay.
doing the same to mine going to run 2 relay off of one trigger that should be ok ?
RAYJAY
UNION DALE PA
Yes, daisy chaining the trigger is perfectly fine.
TY Pa has a different law here for inspection ... have to have all of my xtra lights on low beam only so have to make up a a switch box with high and low beam trigger. been adding lights a long time and never heard of doing light on a low beam ... had to even remove bambi mode from the truck to get it to pass this time ......
