UPR Catch Can Contents at 25K Miles
dtech
colorado
Are you nuts? Uhhhhhh the 2.3T is actually really badass. Crazy good power and mpg, no oil consumption, very high longevity and durability. Toyota, Jeep, etc. are all garbage in comparison to the Cleveland 2.3T. The fuel and water in the oil is absolutely normal for a turbo in the winter. Do some research ??
I know you said "etc" but I certainly would have named Hyundai , cheaply made engines. Agree on the 2.3t overall design but some stuff like the coil moisture issue and egr issues could have been avoided with a little more focus.
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
What is the story with calling it the Cleveland 2.3L? Reminds me of the 351c :)
theprinceofsnj
Richard
Clayton NJ
2019 Ford RangerXL 1959 Edsel Villager 9 passenger
I put on a catch can, to help reduce the buildup of carbon on the intake valves. My mechanic empty's it every oil change.
GhostStrykre
Bee
Ohio
2019 Ford Ranger XLT FX4
What a garbage engine design. Couple that with their stellar transmission and you can tell Ford saw us coming. Jus' sayin'.
my understanding is that there isn't an engine in existence that doesn't see moisture (environmental factors like humidity making a big deal here) make it past the piston rings and back into the crank case. lots and lots of manufacturers rely on owners ensuring that their vehicle gets up to operating temperature (above water's boiling point) so the moisture can evaporate and then pass out of the vehicle like other gasses.
so the water and other little bits of whatever substances finding their way to the catch can doesn't surprise me. probably present in every engine. they're all designed to pass it in some way or another, and some are better than it at others. which brings me to my point: i'm unaware of anyone having an engine failure on the 2.3L that the conclusion was that a catch can would have solely prevented the failure.
it's already difficult enough on manufacturers getting people to change their oil and do regular maintenance. introducing a catch can that has to be emptied regularly would find ford, or any manufacturer, getting blasted for being "high maintenance." i genuinely don't know if any mass production vehicle in existence right now came from factory with a catch can that needs emptying regularly. i'd be curious to know if one exists.
anyway, those are my thoughts in response to you saying the 2.3L is a garbage engine design. i actually think it's pretty good, but that's just my opinion. the transmission? yeah.. that could've been a lot better. i won't argue with you there. then again, i'm at 75k miles, every now and then the old girl gets rowdy and i tell her to calm down and she does. that's worked for me thus far.
TJC
my understanding is that there isn't an engine in existence that doesn't see moisture make it past the piston rings and back into the crank case
Your statement is worded as an "absolute" and it is true. But rarely are things black and white.
Back in the day ring tensions were much tighter in the cylinder, and much much less moisture made it into the crankcase. Modern manufacturers have reduced the ring tension in engines in search of higher gas mileage goals which does allow much more moisture into the crankcase.
Remember ring compressors and wooden mallets / hammers to drive piston into cylinders. Now a days you can squeeze the rings with your fingers while simply pushing the piston in. Sloppy loose.
GhostStrykre
Bee
Ohio
oh wow, this is a learning experience for me today. i didn't realize ring tension played into fuel economy. i'll have to go read up on it. very interesting!
It's probably the biggest source of friction in the engine.
Rocketeer61
Bill
Utah
2020 Ranger STX
Yep. My wife is used to me muttering "Find a gear already." I notice that the "improved" 10R80 supposedly has upgraded parts. I won't hold my breath waiting for a recall so that we can all enjoy the rewards of being beta testers.
fusseli
EE
They are made in the Cleveland, OH engine plant.
fusseli
EE
For certain, or GM and their engines that burn oil and throw rods. My favorite are probably the prized but also gutless Toyotas. Driven a Tacoma or 4runner? They are terrible. The EB, especially 2.3, is an absolute champ in comparison to the competition IMO.
LawnMM
Rich
'23 Ranger Tremor
I put on a catch can, to help reduce the buildup of carbon on the intake valves. My mechanic empty's it every oil.
Mind asking your husband what they charge for that service? I'm curious what I'm saving ?
I'm unaware of anyone being molested by Bigfoot while camping in the woods, but I still bring a gun
They aren't introducing it, it's already there. It's on the driver's side of the engine, and it doesn't have to be emptied because it just dumps the contents into the oil sump if I remember correctly.
Probably why people complain about their oil smelling like fuel. That alone is reason enough for me to add one in front of the factory model I can empty BEFORE the one on the side of the engine fills with crap and starts recirculating it through the motor ? via the oil pump.
I actually JUST emptied this out of mine today after noticing a little extra smell in the engine bay.
That ain't a cup of coffee. It's mostly water/condensation as we've had a bunch of moisture in Colorado the last week. Then mix in some oily congealed goo and a little bit of fuel and bingo! Ecoboost hot cocoa!
GhostStrykre
Bee
Ohio
you do you, boo
