TurboSmart BOV Installation Video
Status
Not open for further replies.
OffroadAlliance
Brockton, MA & Houston, TX
www.offroadalliance.com
2019 Ranger, 2021 Raptor, 2022 F250, 2023 Bronco
Here's the new TurboSmart BOV installation video. Looking for parts for your Ranger? Give us a call at 888-466-8991 or shoot us a PM.
Ranger Performance Parts ---->>>> OFFROADALLIANCE.COM
OffroadAlliance
OffroadAlliance
These TurboSmart BOV's are good in stock!
Mokume
Honolulu, Hawaii
What is/are the advantages of replacing the stock BOV with this?
OffroadAlliance
OffroadAlliance
@Mokume
The factory blow-off valve is largely controlled by the truck's ECU. It's comprised of mainly plastic components and comes with a relatively low pressure spring. The light OEM spring and ECU controlled bleed valve are essentially there for emissions purposes and to protect the engine from high boost pressures. If you're going to upgrade the engine's boost/power, upgrading the blow-off valve is a good way to protect the engine and turbos. When you are in boost, the vacuum reference line keeps the blow-off valve closed. Once the throttle is released or you remove your foot from the gas the engine goes into vacuum. The pressure differential between the manifold and intake blow-off valve then force the valve open. This releases the boost pressure whereby protecting your turbo(s).
So the main rationale to upgrade:
  • Prevent bleeding of boost pressure
  • Made from Billet Aluminium
  • Increased durability and greater strength against fatigue or failure vs OEM
  • Designed to handle increase in boost/power
  • Awesome sound of pressure being released
While not the only reason, one of the most popular reasons to upgrade is the sound.
Mokume
Honolulu, Hawaii
The "awesome sound of pressure being released" is nowadays limited to my visits to the toilet (along with the resulting relief, if I may add).
Still, your product intrigues me...
OffroadAlliance
OffroadAlliance
Not sure what to do with that comment, so going to leave it be.
As far as the TurboSmart BOV goes, it's a very popular addition to the Ranger as well as most turbo'd vehicles. We sell a ton of them for the Ford Raptor as well.
Mokume
Honolulu, Hawaii
Wise decision Chris, very wise indeed !
sbacpo
Claybuster
OffroadAlliance
OffroadAlliance
@sbacpo - Thanks! You responded faster than we could.
@Josh Hager - Dual Port is definitely the most popular of the two options! We run the dual port on both of our shop Rangers.
SpaciousGarage_5G
Jeremy
Riverside
2020 XLT Sport 4x4
Marketing Director
Question - with the Turbosmart Dual Port having a VTA option (which I like), does it pose any threat to vehicles that will be operated in extremely dusty environments? I understand boost pressure is coming out of the BOV, but lets say you're plowing through a silt bed and the BOV actuates...are the chances of debris entering the intake tract higher than a plumb back BOV?
OffroadAlliance
OffroadAlliance
While possible, it's unlikely to have the BOV suck dust/dirt/debris back into the system. We sell a similar unit for the Raptor and plenty of those folks are running their trucks really hard in the desert without issue.
I have this setup for a while but noticed that I've never hear the BOV in action...went out in the garage and gave it a few good revs with hood up, doors open and sure enough, it's working...so my question is under what driving condition can you hear the BOV while driving?
Hi Sid,
Ummmm....only after Enchiladas with a side order of refried beans.... :)
Status
