TPMS false reading
  • Thread starter Okanagan Winemaker
  • Start date
  • Watchers 5
Okanagan Winemaker
Getting a false TPMS reading on left rear tire. Can the TPMS be reset before I take
it in to the dealer. Thanks..............
Strokerduster
Yes but requires a tool. Take it to Quicklane if your dealer has one.
t4thfavor
Chance
Swap it to the other side and see if it moves. If it does, it's probably just a TPMS battery, if it doesn't then it's worse. Either way you still take it in.
South Florida Ranger
Hollywood, FL
2019 Ranger FX4
I am having the same issue, but it is only the left rear. no matter what tire I put there it remains --
I have the resetting tool and my mechanic has an even better tool and the left rear will not respond.
I just know I can take a tire that reads fine in one location. Move it to the left rear and when I reset it comes up --
Truck has 160,000 miles.
t4thfavor
Chance
So something has happened to the sensor that takes the reading from the tire sensor then. It shouldn’t be too much to replace it. If it’s still bad, then the issue is up in the wiring between that sensor and the computer or the computer is flaking out which isn’t likely.
Waltztj
Walt
2021 Ranger Xl
You don't need a tool to reset the TPMS
1. Turn the key to the on position but do not start.
2. push the hazard button 3x then it will beep once and the dash menu will tell you to go to the left front tire.
3. let air out of tire till it beeps once then mover around the truck as it says on the dash menu.
4. After you do all 4 tires it will beep 2x and you are done.
Works on my 2021 Ranger.
Now they are the same as my tire pressure gauge.
Hollywood, FL
2019 Ranger FX4
Exactly. Now to find that sensor.
Hollywood, FL
2019 Ranger FX4
Thank you. Done this many times. The left rear continues to not register. I also have the tool that does this without letting the air out.
If I understand correctly, no matter what tire / wheel that is in the LR position, you have no indication (X) or (-) on the TPMS display for that position.
The sensors transmit data via radio frequency to the RTM (Radio Transceiver Module)
The RTM transmits this data to the BCM and GWM.
So, you may try doing a BCM and RTM - Self Test (Reset) to see if it brings the reading back.
You will have to drive it to see if it helps (relearn) as the sensors require rotation to transmit (update)
Hollywood, FL
2019 Ranger FX4
Yes, you read that correctly. Can I reset those from the dashboard menus?
Thank you for this information. It helps a lot.
Happens all the time with my right rear...comes and goes...I just ignore it...there's no leak or flat...just can't get signal once in a while...
Hollywood, FL
2019 Ranger FX4
My left rear was doing that also. Working, not working. Then finally stopped. Almost like a wire or plug disconnected. I was running my truck real hard on trails too. I stopped doing that though.
Use Scanner or Forscan ?
If you do have have either you might try pulling the RTM fuse for a few minutes and see if that helps - Fuse 32 Interior fuse box.
ColdRedRanger
Austin
Cold Lake, Alberta
2021 Ford Ranger XLT
I started having the same issue of only rear left. Started after I got new wheels installed. Tire shop replaced the sensor under warranty but rear left popped again. I just ran the "Train Tire Sensor" reset. Fingers crossed it helps but as I learn more I will update my experience with it.
