ControlNode
- First Name
- John
- Joined
- Nov 29, 2021
- Threads
- 16
- Messages
- 1,710
- Reaction score
- 3,643
- Location
- Eastern NC
- Vehicle(s)
- 84 Civic "2000S"/16 Focus RS/21 Ranger XLT
- Occupation
- Computers
@airline tech Yeah the only data out of the US switch is on the can bus (HS2), I don't even think the US switch internally knows where it is. I think it just signals that the rotary knob was turned left/right (-/+) and if the TM switch was pressed, it listens on the can bus for what it should indicate. So, no real way to direct re-pin the ROW Ranger to support the US switch. As mentioned, it could be done if someone was really wanted to build a module to "rosette stone" the two systems.
and had a rotary switch in my head. (Signal return = Switch Position via the voltage measured on the return circuit) the voltage will vary depending on switch position from the voltage drop across each resistor (switch position)
