Lablanca2019
- First Name
- Armando
- Joined
- Oct 1, 2025
- Threads
- 3
- Messages
- 35
- Reaction score
- 28
- Location
- Edinburg, Tx
- Vehicle(s)
- 2019 ranger stx
- Occupation
- fuel hauler
- Thread starter
- #1
First time poster long long time listener.. But anyway I need some help.. Recently had my stx 4x4 go thru a full suspension make-over..
upgraded from stock to Eibach stage 2 pro truck full kit followed by Icon rear leafs.. as for the ebach's they were installed as built from factory and front lift was about 2-2.5 inches and leafs also installed as built.. But unfortunately truck came home with dreaded take off shudder, I quickly figured out it was because the leafs lifted the rear more that the advertised .375.
So as my first line of defense I went ahead and added some shim's on the center support bearing and it most defiantly help reduce the shudder to an almost livable amount, My question is has anybody else experienced take off shudder after icon leaf swap and are there any known axle shim kits that I assume would be the best route to eliminate shudder vs dropping the center support bearing since I know it affects both sides of the drive shaft? I hope all this makes since..
side note. I currently have 2- 1/8 shims stacked on either side of the support bearing..
Thank you for any input I can get
