- First Name
- Chris
- Joined
- Mar 15, 2020
- Threads
- 164
- Messages
- 7,539
- Reaction score
- 10,750
- Location
- Elizabeth, Colorado
- Vehicle(s)
- 2012 Nissan Frontier, 1994 F150 XL, 2022 Ford Transit
- Occupation
- Field Service Technician
- Thread starter
- #1
This is going to be a nice introduction of SuperPro Control Arms that have recently become available. Though I may specify a bit for my Frontier, things will be similar for the Ranger as they have a set available for the Ranger.
Now for those that are not aware, SuperPro is a Australian Manufacturer for Automotive Aftermarket Suspension Bushings. They are part of Zeder Corporation which includes Whiteline Performance, Fulcrum Suspension(another Australian Manufacturer), Nolathane and Formula 4x4. Some individuals on here including myself have used either SuperPro or Whiteline Bushings and have been happy with them.
Well as the Title states this is about the Control Arms that they offer now. In Australia they have both Fixed and Adjustable Control Arms available. In the US at this time we only have the Fixed Control Arms available. Regardless these will still make a difference on helping the Suspension stay in alignment Specifications after a Lift or Level.
To help give a quick understanding of how it can help, here is a Video from Zeder Corporation on the SuperPro Control Arms.
For those that want to see the Ranger Control Arms, here is the link to them!
https://superprousa.com/products/ge...er-control-arm-set-fixed-offset-lifted-trucks
Now for my Frontier I do have a Small Lift on it from Dobinsons. The lift has given my truck 1.5 inches of lift front and back. Though it isn't much, the alignment is rough especially on Caster. To put simple it has been maxed out on Caster and the Camber is a +0.9° on both sides(keep in mind the specifications for Camber is 0°). Below are the results of my last alignment and I knew I was going to have to make an adjustment.
Well the SuperPro Control Arms will add up to -1.5° of Camber depending on lift height and will add between +2.5° to +3.5° of Caster depending on lift height (keep in mind these numbers are specific to the Frontier and not the Ranger). After looking at what my option were with price and manufacturers I decided to go with SuperPro/Whiteline(same company and part, just different color).
Thankfully there was a place nearby that had them in stock and they arrived today in the mail! After I got home I decided to open the box to get a closer look! Up close they look really nice. It uses SuperPro Bushings and a nice grease able heavy duty ball joint! I can also get a service kit from SuperPro in the event I need to replace the bushings and ball joints.
Now I am planning to install these on Saturday and will give more information on them afterwards. This will also include how much the road manners change. Hopefully it makes a real nice difference on ride quality and handling. Only time will tell.
Just hang tight for the next part!
