DangerRanger01
- Thread starter
- #1
Hey All!
Quick question for those of you that have installed an aftermarket sub and amp.
Recently purchased and installed:
- Hertz HCP1D
- Rockford Fosgate Punch P1 10" 4 ohm SVC
- power & ground wires are 4 AWG w/ 60A in-line fuse on power
I haven't done anything to the factory stereo, and I used the rear speaker wires as the hi-level input for the amp, as this amp has a built-in line converter.
But here's my problem, upon listening to the new sub, it's very quiet and is not producing what it should, I made sure the "driver seat" setting for sound and the speed compensation were both turned off in the EQ settings, and even with the BASS setting turned all the way up, the speakers are overpowering the sub!
I double checked to make sure my wiring is proper, and I don't have any loose connections (including ground, I sanded to bare-metal). Really disheartening to know that I've spent some hard earned $$$ to be disappointed with the end result, I've read over every forum for a sub install, and I may try the Forscan setting that changes the low-level settings, but I'd like to see if anyone is also having issues with this.
- Hertz HCP1D
