May I be so rude, as to ask the source?Working on some
More carbon interior pieces ?
How has nobody brought up that at 1/4 of a tank it says 44 miles to emptyWorking on some
Once o receive the rest I’ll provide the source hahaMay I be so rude, as to ask the source?
That’s what 34” tires, full bolt on, tuned, and fiberglass gets you ??How has nobody brought up that at 1/4 of a tank it says 44 miles to empty
Yea it a game changer for sureDoes this change the weird 9-3 feeling that the OEM wheel has? Is the shape different at all?
How was this install Allen? Mine is coming next week and I need to start seeing how to remove and reinstallYea it a game changer for sure
install wasn’t bad at all, the hardest part I’d say is removing air bag. Which is still not bad.I used a welding rod to stick inside the hole on each side of the wheel to release the pin on the airbag. Make sure you unplug your battery before install. Then the rest is not bad at all. Just take your timeHow was this install Allen? Mine is coming next week and I need to start seeing how to remove and reinstall
Sweet!! Getting the airbag out obviously freaks me out, so to hear its not as bad as I am thinking calms me down a bit. Thanks Allen!install wasn’t bad at all, the hardest part I’d say is removing air bag. Which is still not bad.I used a welding rod to stick inside the hole on each side of the wheel to release the pin on the airbag. Make sure you unplug your battery before install. Then the rest is not bad at all. Just take your time
Yea and taking all the trim off isn’t bad at all.Sweet!! Getting the airbag out obviously freaks me out, so to hear its not as bad as I am thinking calms me down a bit. Thanks Allen!
You would be surprised with the amount of HP It addsThat's still a lot of money for a steering wheel.
Not ragging on you, mind you.
Just amazed at how much such a thing can cost--uninstalled.
Dang!
