Simple level
I was going to have it lined up is that what you mean
There are several pitfalls to avoid if doing this yourself and if the $500 quote includes a wheel alignment (necessary after a lift/level), that’s a pretty good deal for a lot of peace of mind.
There are plenty of discussions in the Suspension/Chassis forum that cover the procedure.
If you do it yourself, all the best.
onobeka
Romania
2018 Ford ranger 2.2 European model
That is what I meant, but it's more than a "lined up" procedure. It's toe, caster, camber. Probably toe and camber will be mostly affected, depending how you do the procedure, caster not so much. Regardless if you do it the UCA or the LCA way, the toe and camber will need correction.
onobeka
Romania
when you try and rush and/or take the short cut and pull your shafts out by mistake....then you'll really be thinking that $500 was worth it.
If you want to do the install yourself, IMHO the safest way to do it is to disconnect the LCAs one at a time, of course, the UCA remains bolted in place. Yet, please make sure you run a strap between the two LCAs to avoid exactly the shaft pull. The straps keeps the disconnected LCA from pulling the CV or angling it (like in the UCA way). Of course there is the option to disconnect the shafts from the hubs, but that's not that easy.
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
When I did my 2.5 spacer install I took the axle nut off in order to keep the axle shaft from pulling out. I left the LCA‘s bolted on though. Everyone knows you Never pull out!
onobeka
Romania
Indeed, that's the way to go if you want to be on the safest route, yet with a wheel alignment they will anyway loosen the LCA bolts, there's no other option, so I did it the LCA way.
HTX1811
HC
Houston, TX
19 Ranger STX 4x4,16 Audi A7
Did you have to remove any crash bars?
I want to run a narrower but bigger tire for my adventures in Colorado.
I did not have any rubs issues with the crash bars installed. I now have an aftermarket bumper which required the removal of the crash bars.
Ordered the RC 2.5 inch yesterday the local custom shop said 500 to put it on I think that’s a little steep for a couple spacers going to try and do myself has anyone done this / how difficult is it
If you follow the directions it is a very simple job especially if you have ever messed with removing front struts. I did mine 19,000 miles ago and have had zero issues. It’s not a difficult install compared to other jobs. New intercooler, new front bumper, a bit more work but I’m not a novice when it comes to shade tree mechanic. All self taught over the last 40 years but if you are mechanically inclined at all and have the tools, do it. Then get a professional alignment.
patipton
patipton
ohio
2019 ford ranger
Thanks for all th info I have found a local tire and alignment shop that will do it for 350 for everything that’s better than 500 for just the install will post pics when it’s done
