Should there be any play in the CV joint?
RangerFD
J
Northern VA, United States
Firefighter
Wondering if this is normal. If I pull towards the wheel you can hear that sound it makes towards the end of the video.
Jfleming
Brecksville OH
2020 Ranger Lariat 4wd Supercab, 1996 Ranger XLT 2WD
Fireman
That looks pretty normal to me. (End to end clearance) Where you don't want to see any play is if you would rotate the shaft and either end of it has play in it in relation to the shaft.
RangerFD
RangerFD
J
Firefighter
So just to dumb it down to myself it can go forward and back but not up down/ left and right?
geophb
Mechanical Engineer
Normal. A brand new shaft would be the same.
There will be some play goin in and out like that (its splined).
Up/down/all around/rotational it should be tight.
Monark323
Alex
San Bernardino
Ranger XTL FX4
Mine had play too, so I open the boot and found a piece of broken metal inside of the boot. Probably broke the driver side CV joint when I install my coilovers.
FYI buy straight from the online Ford parts store it’s much cheaper than straight from the dealer.
