Rear suspension
Richard
Quebec, Canada
Ford Ranger Lariat fx4 2019
Hello, I have a Lariat FX4 2019. 15 kilo. I only drive on beautiful roads and put no load in the box. My shock smashed. The garage has been renovated, but the suspension is not correct. It leans against all the bumps. Do you have any advice. thank you
write your problem in French since its your comfortable language.
Google translate should do a good job with the change to English and maybe we can help with your problem a little better.
I apologize right now because I'm not sure what you're saying.
You crack me up:crackup::crackup::crackup:
but I'm serious though.
Im not fluid in french, and i know how I sound if I try and speak or write it, so I understand his pain.
I've carried on a decent conversation by text and emails for work by using google. may not be perfect, but it eliminates alot of misunderstandings
There's an app for that...Seriously It's called iTanslate Translator if you have an iPhone. Trust me living here I have no idea what most are talking about!
Richard Simard
Richard
Quebec, Canada
Bonjour, j'ai un Lariat fx4 2019. 15000km et je n'ai jamais roulez sur des routes cahoteuses et jamais transporter de charge. Mes shock arrière ont défoncé. Le concessionnaire les a changer. mais le problème persiste. Quand je roule et je rencontre une bosse, la suspension vas accoter au fond a chaque fois. Ils m'ont répondue que je doit accepter ce défaut du Ranger.
Richard Simard
Richard
Quebec, Canada
Hi! I have a Ford Ranger FX4 Lariat 2019 with around 10k miles on the clock. I only drove the pick up on city roads / highways, and never transported stuff nor tow hauled anything. The Ford dealership garage changed my rear shocks because they were desealed / shut. When I drive over bumps the rear still goes to the ground and knock the shocks to the floor each and everytime. The dealership says thats a known issue and I'll have to live with it. Anyone have/had same issue? Any help? (a friend of mine translated my text for me)
:facepalm: It's way to early for this.
So you're saying the rear shocks bottom out over normal bumps?! Ah nooooo we don't have that issue...they're lying to you:crazy:
