Question - Wheel Size
IDriveARanger
Toronto, Ontario
2019 Black Ranger Lariat
Yes
Hi Everyone,
First time posting here. I have a 2019 Ranger Lariat black edition. So far I’ve added an MRBP twin exhaust, mishimoto cold air intake, mishimoto baffled oil catch can, and blow off valve.
I’ve purchased the Eibach pro kit, and plan on raising the front about 2”, I still want a little rake to tow my fishing boat without the front end poking up. If I lifted the frontend by 2”, do you think I’d be able to get away with 275/70/18 wheels that are 50mm offset?
Thanks in advance!
C
You mighr be pushing it with that size. Assuming you have factory 18 inch wheels I suggest going with a 65 sidewall. I myself run 285/70-17 and that would be equivalent to 285/65-18. Also depending on the tire you choose will depend if you have to worry about clearance as not all tires are made equally
Dave1899
Florida
2019 Ranger Supercrew Lariat 2WD
Retired Living the Life
Welcome to the tribe.
