P0630 Help
commbubba19
Omaha
2020 Ranger XLT FX4 - Gots mods
Network Engineer
Code: P0630 - VIN Not Programmed or Incompatible
Ran into this after running a Forscan ABS test. Now it won't clear. Strangely in the PCM and BdyCM entries the VIN is there and correct.
I'm stumped on what happened.
  • Sad
commbubba19
commbubba19
Omaha
Network Engineer
i recall others having this issue.
try a forum search to find the threads about it
I did. Nothing came up besides a LMS query about tire size Changes via Forscan.
commbubba19
commbubba19
Omaha
Network Engineer
I’m not following. I’ve searched the entire site for that code and no results found. So if you have a specific link to more information please post it.
Thanks
I believe this has to do with the LMS tuner doing the tire size change. Forscan didn't like something and between the tuner, forscan, and my truck it wasn't happy. I ended up restoring the PCM and BdyCM to original as built. I then did a PCM initialize/relearn. After that the CEL cleared and the code was gone.
I then went back to my LMS tuner to update the tire size back to where I had it. Factory I think is 683 or 681 and I change mine to 647 for 33's.
Went for a good 20 minute drive and now CEL so I think I'm good. I had read on the forscan forums that others have had issues using Forscan to change the tire size vs a handheld.
I hope this helps anyone else who might run into this.
CO2Ranger
Running into a similar issue. Did your fix work permanently?
CO2Ranger
In case anyone else runs into a similar issue, I had to restore to Factory AB using FORSCAN. Using the as built files I created when I first got FORSCAN didn't actually fix the issue.
To clarify:
- Loaded factory AB for PCM
- Loaded factory AB for BdyCM
- Ran PCM initialize/relearn
- Gravy
DrdPrtRlf
South Carolina
2019 Ranger XLT 4x4
To clarify:
- Gravy
This got me out of a huge jam. Thanks dude!
