New shocks messing with backup camera?
Millwright78
Don
2019 Ranger Lariet Crew Cab
Retired Millwright
Had new bilstein shocks put on today. Now there's a warning on the screen to check around behind me on the passenger side. Cleaned off the taillights as I thought the sensor was in there. Didn't help. How can changing shocks screw up what, Ford Co pilot 360?
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
if it affected the height of the truck, it may need recalibrated
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Since you had them put on, my guess is they bumped a backup sensor. Or a wire for one is loose. Is it the back up beep or cross traffic warning? Cross traffic uses the blind spot monitoring radar in the taillight.
The Taillamp Housing contains the (SOD) Side Obstacle Detection or AKA BLIS module.
This gives you the (Mirror) light for Blind Spot it also serves as the Cross Traffic Alert when in reverse and you have cross traffic behind you.
The Rear Parking Sensors (4ea) alert when in Reverse and an obstacle is detected near the bumper. (The small round discs) in the bumper.
This is indicated the same as the Front Parking Sensors, a Yellow / Red indication on the Sync Screen.
One of the sensors may be dirty or got knocked out of place or the wire harness got bumped / damaged in the process.
I would try cleaning the surface of the sensors and resetting any codes (if any) and also note on the sync screen which sensor is triggering - R- Inner or R-Outer
Millwright78
Don
Retired Millwright
It's a back beep. Shows left side.
RangerPNW
Thomas
Santa Fe, NM
Project Manager
Connector on the sensor is probably loose, i have that issue occasionally. New rear shocks wouldn't effect any of those systems as shocks alone don't effect ride height
