New key fob
Hellrazor
Clement
Richmond
2021 ranger
Baller
How do you program new key fob for 2021 ranger lariat With push button start? I only have 1 key and wanted a spare. I got one off amozon for $35
GreyAreaRanger
Houston
2019 Ford Ranger XLT
Surgical Nurse
I believe you need Forscan to do it. I had a local locksmith where I got a new fob and key from that cut and programed a second one for mine.
MarioCart
Mario
Canada
Ranger
Employed
Ive seen many techniques online how to do it. not sure if they apply to an online purchased fob or not.
has to do with cycling the key, pressing buttons, chewing gum at the same time etc....
Never tried it, so mileage may vary.
Jason B
2021 XL STX SE 4x2
machinist
End of line 2 states "If this doesn't work, then it's possible your car is equipped with keyless entry. Contact Ford service team for assistance."
OP has a Lariat. Do all Lariats have keyless entry??
Craig
Craig
SLC
Go to a locksmith they should be able to do the programing and the cost is lower
kendive
Ken
23 Ranger Lariat Tech Pkg Tremor
If you have keyless entry and you have two keys programed already you can add a third key. probably in your manual. I did this for my F150 very easy...
The key is No pun attended you have to have two keys programmed already.
jmelair
Rockledge, PA
23 Ranger XLT Tremor
End of line 2 states "If this doesn't work, then it's possible your car isn't equipped with keyless entry. Contact Ford service team for assistance."
I saw that too... (corrected as noted).... do they mean keyless start? My XLT has keyless entry.
also, if they truck has a pushbutton start, how are you supposed to turn the key when there isn't an ignition switch to turn it in?
kendive
Ken
Turning the key with keyless start is just pushing the button once but do not have your foot on the brake the truck will boot up but will not start.
MarioCart
Mario
Canada
Ranger
Employed
good point.
I tried.
