My wifey's truck build
Phessor
Phessor
Arizona
2019 Ford Ranger 4x4 XLT Crew Cab
First long trip with a full cab and the rear passengers had something to say about the jolting ride.
So I took advantage of the inexpensive global Ranger Wildtrak leaf packs out of England.
After they arrive and are installed I will give a trip report.
Phessor
Phessor
Arizona
I plan on installing my global Ranger Wildtrak spring packs tomorrow. So before that happens I went out and took some base line measurements.
I will update the measurements after the install.
Phessor
Phessor
Arizona
Install of the global leaf pack went pretty quickly. I did utilize the factory spacer on the drivers side and I installed the "+" spring on the drivers side as well.
Here are the post-install measurements after a short drive around town to settle things in.
I gained .875" on the drivers side and a full 1" on the passenger side.
I am going to order a longer center bolt and install another spacer below the drivers bottom overload spring to see if I can level it out more.
I can tell you there IS a difference in the ride quality of these springs. They are worth every penny for sure.
Phessor
Phessor
Arizona
As our world becomes more and more disrespectful and inconsiderate.
I learned a trick from an old cowboy, they're called the a hole behind me lights.
I have a set of lights like this on every one of my vehicles that I drive, and trust me, I have had to use them many times.
Turn your brights off!
Rhino
jacob
idk help!
professional anime watcher!
An older picture, it now has an ARB front bumper and new wheels.
looks pretty good i dont see much rust in the usual spots!
