Mounting next week!
RangerDeej
DJ
Houston, Tx
2019 Ranger Lariat FX4
Just received shipment of my new wheels this afternoon.
Black Rhino York
17x9
-12 offset
Still waiting for the extra set of factory TPMS sensors, they should be here Monday. I'm wrapping them in the 33x12.5 KM3's I anxiously bought in December while waiting for the truck. I will keep you guys updated along the way.
Stic-o
Lake View Terrace, CA
Are the TMPS sensors just valve stem ones or do the mount around the wheel?
Another option I did before, is put all the sensors in a closed PVC tube, add a valve stem and pressurize the tube. Throw it behind the back seat.:fistbump:
FLEngineer
Orlando,FL
2019 Ford Ranger Lariat SCrew
This is hilarious :LOL:
Stic-o
It works.. Ran a set of 2011 Mustang V6 take off rims and tires on a '06 Explorer for a few years like this, until it neeed tires again, and I could remount the sensors. Just put the pressurized tube with the spare.
Oregon Comrade
Portland, OR
2019 Ranger FX4
Black Rhino York
17x9
-12 offset
Those will be awfully close to fitting, what is your plan to get them to fit if you have clearance issues? The reduced offset is going to help....
RangerDeej
RangerDeej
DJ
Houston, Tx
So last night I got the tires mounted and spacers installed (Took the bait on the ones posted from Suspension Specialist.)
Currently, without any body mods I'm rubbing in 3 places.
In drive, I can get 1 1/4 turns in my wheel, and about 1 full turn in reverse
I will update on locations, and modifications after I get into everything this evening.
LewisLegacy
Dayton OH
2019 Ford Ranger XLT
That looks sick though. What offset on those wheels? Gotta be close to 0.
Bubbabiker
Ford F150 Supercrew FX4
Curious what the setup would look like with +18mm offset wheels.
Oregon Comrade
Portland, OR
2019 Ranger FX4
You may have better luck taking off your spacers depending on where it rubs. You'll probably still have enough room between the tire and the spindle assembly. I'm guessing it rubs the worst on the outer edge of the front tire on the front wing. That wing is going to need to be removed, the one that bolts to the frame with (2) big bolts.
RJohans
Bend, Oregon, USA
2019 Ford Ranger Lariat 4x4 Supercrew Sport
Black Rhino York
17x9
-12 offset
Dude! Those are sick! I want them for my Ranger now on order!
@Robby887
Diamond Sponsor
Robby Woolworth
Las Vegas
2019 Supercrew Fx4 xlt ford ranger
Fabricator/welder
