Linkswell multi camera module
LB'sTremor
Loren
Tampa
22 Iconic Lariat Tremor
IT
To all the Linkswell installs out there anyone use the multi camera module? If so how do you like it?
Thanks!
LB
Deleted User 38384
Thanks!
LB
I didn't. But I'm considering it for the front. I miss my superimposed image on the screen. That is the ONLY thing I liked about Sync3. The proximity tones still work. But I would like to regain some type of top-down image on screen to show me how close I'm getting to an object. Or, go with the extra front camera. Or,,, Linkswell needs to figure out a way to make it work again.
It's weird that the superimposed image of each proximity sensor works fine in reverse... why can't they make it work for the front as well ?
LB'sTremor
Loren
Tampa
IT
Thx for the reply yes front and blindspot cameras would be awesome on a big screen. I don;t think I have ever seen that proximity screen on my sync 3 do I have to enable that? I have a Lariat with 501A package.
LB
Grandaccess
Binghamton, N.Y
Computer Consultant
Thats a pretty wild 100 degree Temp swing from 7 to 106?
LB
If you are referring to this:
It pops up when you get in close proximity of an object (In Drive) and low speed.
Note the (Left Outer) sensor is red here.
I actually use this screen pulling into the garage, when it turns red - I am perfectly spaced between my air compressor / bench and my garage door.
So its the same image you get in Reverse, just zoomed in without the rear cam image
