Infotainment Display Periodic Black Screen
Jan
Indianapolis, IN
2022 Ford Ranger SuperCrew Lariat
Since buying my 2022 Ford Ranger Supercrew Lariat, I am "periodically" getting a black center dash infotainment display when I start the ignition.... nothing, no NAV,Audio,Phone, etc. displays... just a black empty screen. To get it to work again, I need to shut off ignition and leave it sit for awhile before getting back in and now again pressing break petal and hitting the Start button. When I talk to Ford Service, they can't find anything wrong since, obviously, it works fine when I can get it in for servicing. Any suggestions? Thanks all....
When mine was new, my screen would randomly reboot...goes black then the Ford logo comes back on...hasn't happened in a long time tho...
Jan
Indianapolis, IN
Right... I do not get the Ford logo at all, and thus nothing after that. Thanks....
Reactions: EJH
jblc
JB
USA
2021 XLT FX2 supercab
I've had the same issue. It occurs every few months, and goes away after restarting the vehicle.
Interestingly, i think it's still active, since pressing the screen seems o hit buttons (as evidenced by button pressing sounds, if i hit something that would normally be visible)
Stevo56
Duluth, MN
2020 Ford Ranger XLT, 2023 Ford Edge SEL AWD, 2012 Ford Mustang
You could try a master reset. It is in the "General" area of the menus. This seems to fix a lot of gremlins floating in the system. You will have to re-pair your phone after this.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
This is not a solution to the problem but holding the radio Power and seek forward >> buttons together for 5-10 seconds will reboot the radio. It will probably get you going again without having to restart the truck.
12Bravo20
Missouri
2020 Ford Ranger XLT FX4
My screen went blank once and I couldn't do anything with the radio. I got home and did the soft reset following the above instructions and haven't had a problem since.
Noface
Jes
Mountains
Ranger
Nerd
Not sure why it goes dark but I just hit that button to bring it back.
Jan
Indianapolis, IN
Thanks... I was unaware of that back door reset. I haven't had the problem since my original post, but I did test your reboot instruction and see that it does work. I will use that back-door reboot next time the problem arises.
