I bent my WheelHorse Tractor & Me!
TJC
Well.... had to head back to the Doc yesterday. The infection in the left knee came roaring back! Doc says you came in at the right time. This time around 2x daily Cipro for 30 days ( last time was 1x Cipro for 10 days).
Doc tried to take a sample using a BIG needle and syringe, but only got blood. That needle hurt going in and hurt worse when He tried to draw from it. Bled like a son of a gun. It is painful again, but I think it is only from the after effects of the failed jab.
He actually marked the outline of the infected patch and dated it with indelible ink so we can determine progress. Doc stated that it should start shrinking on day 3. At this point I will take Cipro to well past the time it looks all clear.
The right leg is healing but he cautioned not to over use it as the muscle tear is still mending... I need to stretch it regularly, but not over stretch it to the point where it tears loose.
I am not letting it stop me from working outside, but I do pace myself. 2 months in and still dealing with this.... sigh.
Such is life.
Radioman
Kent
Roseville, CA
Such is life.
Hang in there Tony. it WILL get better...
Such is life.
with such a tough infection i wonder if you have some debris in the leg, rust, shrapnel or something from the fall. even a splinter can make an awful lot of infection... hope its better soon keep us posted
TJC
We've considered that something penetrated, but the wound was the simplest and slightest of all abrasions that I suffered. Strange. Doc was very concerned.. "take the Cipro at the pharmacy - DO NOT WAIT!" Hr told me that it will be two days before it begins to work, it will get worse before it gets better.
It got worse yesterday, spread 2" up my thigh, and last night for the first time I had a fever 99.8F. I normally run 97.6F.
Good news is that the fever has dropped this morning to 98.4F and the area seems to have stabilized.
So I should be seeing an improvement by tomorrow.
sure hope so!
TJC
I've been on 3 antibiotics since my last update, and they have only slowed the spread....
Until Tuesday evening!!! When I tried using CDS directly on the infected area at 1000PPM (soaked thoroughly on a washcloth, and held in place with a thin cotton wrap for several hours. I am also consuming CDS @ 20PPM in 5oz of water on the hour for 12 hours.
The Result - Overnight the infected area shrunk back to the size it was on Sept 1. We know thios as we keep the original mark from that date (Doc temporarily tattooed me).
This is remarkable progress and the first positive report since this infection began. The infected area also began to seep white blood cells out of the infected area in droplets (puss). Another positive sign. The swelling in my left leg also dropped to near normal size at the same time. I can put my left shoe on again! I walk normally now, but the infection is very real and still very large and painful. However it is not as thick as on Sept 1, and is beginning to scab over a bit.
I am heading back to the Doc in the AM to get a refill on syringes and needles as my wife now administers the shots in my butt! I will then go back on Monday.
I am praying that we have turned a corner. My CDS consultant in Switzerland expects CDS to cure it in 6-8 weeks if I keep to the regimen. But I will be staying on the antibiotics as well.... don't play with the recipe if it is working!
My doctor I think is about ready to urge me to head to the hospital, unless we start seeing positive results. He is at a conference this week and we only communicate via email or phone calls.
A word of warning. I am in this state due to an ultrasound requested by my doctor and performed at another lab. The infection appeared 3 days after the ultrasound was completed. Doc thinks that is where I picked it up as well. Be sure to watch the technician sterilize any instrument that comes in contact with a scratch or scuff. This wound was trivial compared to all my others, and they have long since healed.
Ever onward.
Ever onward.
oh man! i would be very upset if i got infection from a medical treatment... i admire your positive attitude. good to hear something is working.
TJC
I don't intend to gross anyone out, but here are 3 pictures showing how quickly Antibiotic Resistant MRSA attacks even with massive antibiotics being taken.
Here is the initial wound. It was a mere surface scuff, but there was internal damage that needed to be understood ( blood flow /to from the leg), hence the need for the ultrasound. There was massive leg swelling from hip to toes. Over twice the size of my right leg. Doc had me in leg compression socks.
3 days after the ultrasound the infection rapidly spread and was the size outlined in the black line. 7 days of 2 antibiotics slowed but did not stop the spread of the infection. Low grade fever set in. The skin is shedding due to the side effects of the antibiotics.
14 days with antibiotics and I day after the initial CDS wrap - the results are surprising. The area has shrunk and has started to ooze white blood cells. This is a positive thing.
It looks a little worse today, but I am still hopeful.
We'll see how this turns out, as MRSA is a threat until it is completely destroyed. It can resurface with surprising speed. And once it enters the blood stream, Sepsis sets in and is life threatening.
Very painful and a slow recovery. Force any medical person to sterilize the tools in front of you. It simply is not worth the risk.
- T
good grief brother that looks painful. i wonder if having the doc drain it would help it heal faster. i had a really feisty boil on my arm and doc poked a hole in it and squished out all the goods. then used a syringe to put some antibiotic cream in the hole. healed up quick after that. i know its far from the same situation but might be worth asking.
TJC
We tried that. Nothing but blood and a boatload of pain. It is extremely painful. Even having sweat pants touch it sets off alarms. Basically the artery running down the inside of my leg was compressed and started leaking seriously. It swelled the area so much that the vein was pinched limiting return flow causing the leg to swell to double in size compared to the right leg. Doc hit the pool of blood, and I howled!
CDS is controversial, but I promise you the stuff is amazing. I poured a concentration of 1000 ppm CDS (made it myself) on a small washcloth and laid it on the infected area, then wrapped it in a cotton band for 5 hours. Took it off and was amazed how much smaller (radius and height) the infected area was. The washcloth was soaked with white blood cells that were seeping out of the infected area like teardrops. They continued to seep out for 2 hours. I think I am going to continue to do this procedure every 2 days and see what happens. Still on the antibiotics for a while yet, but 14 days of 3 antibiotics didn't have the effect of one external wrap of CDS.
This is it as of this afternoon! It is Shrinking! Still got a long way to go but this is the first positive progress we've seen in a month,
This morning Sept 15 sees more improvement! 2 Days after CDS. I think I am over the hump! I will continue all treatments until it is clear, but I see the light at the end of the tunnel.
TJC
Chlorine Dioxide is a fascinating molecule. I have learned a great deal about it... it simply cures all manner of ailments, infections and cancers!
On Sept 18 I started doing lukewarm 30 minute soaks in the bathtub with the 160ml of 3000ppm CDS solution that I made in the kitchen. The results are simply amazing. After informing my Doctor what I had been up to, he stopped all medications and let me run with CDS on the condition that I send a daily report to him with an image and stop by to let him examine me twice a week.
I was highly skeptical but didn't want to find myself in an ICU ward. I informed him that I was going to become my own test subject to determine if all the hype I had read about and viewed about CDS was real. After all, the US Gov says it is "bleach" and will kill you. Searches on Google and Youtube say the same thing.
Now take a peek at the attached PDF which covers my progress for the last 10 days. The speed of the healing going on is amazing. I am taking nothing other than CDS. I was on massive antibiotics (including daily injections in both hips in combination with 2 other antibiotics for over a month - that did nothing... anf things kept worsening. I had 2 different bacterial infections, both highly antibiotic resistant, MRSA plus another more dangerous strain. My doctor was very close to sending me to the hospitalization. I do NOT like hospitals.
The last culture (~5 days ago) showed MRSA cleared out, but the other still in heavy overgrowth.
I have been spritzing the infected area, drinking 5 oz hourly, and soaking daily. I think the soaking is doing the heavy lifting.
I can see the light at the end of the tunnel now. but I will continue with the CDS protocol for a few weeks after the infection appears to be gone.
I am now convinced that CDS does exactly what its advocates say it does. I don't think that I will ever take an antibiotic again.
BTW, my Doctor's last statement to me was "Wow! Awesome!"
For more info on CDS search on rumble.com. Youtube is censoring the subject.
- T
- T
All I can say is wow! Amazing results. figures the govt would block it here. no profit in cures. only profit in milking out treatments and lots of prescriptions. I have to admit when i see the word chlorine my mind instantly says bleach - dangerous. I dont like being in hospitals either. glad your getting better! Thank Jesus
