Go Rhino - now shipping "Raptor style" RB20 Running Boards
BaGMaN
Arizona
2019 Ford Ranger Lariat
USAF Retired
you would think the raptor would have rock sliders if it's all that off-roading....
Jim C
MI
19 Ranger
yes they are & nice at non-slip. they are the closest to the rhino in looks IMO
FULLSCALE
Adam
Ontario, Canada
Does anyone have pictures of the RB10 and/or RB20 from the front or rear corners of the truck? The pictures I've seen make them look like they stick out a lot, I'd just like to see them compared to the body and stock wheels/tires.
RARE5.0
Stephen
Usa
2019 Ranger Lariat Supercrew Fx4 1988 Mustang Notch 5.0
I agree. I drilled mine out. Use about a 1/4" bit. Don't drill all the way through!! Just enough to remove the rivet head. They are aluminium and very soft. The holes left are 1/8" and you would have to be looking close to see them. Maybe I will get a picture tomorrow.
Edit: Here are pictures. Hard to see the holes where the label was.
What mudguards are those?
gfitzge2
Gregg
Louisville, Kentucky
Retired Electrician
RARE5.0
Stephen
Usa
Desert_5G
Eric
Arizona
Tacoma
there is some play in the brackets that let you slide them in or out. so everyone's might look different.
FULLSCALE
Adam
Ontario, Canada
Thanks, I didn’t know that. I’d still like to see some pictures if anyone has some!
gfitzge2
Gregg
Retired Electrician
They stick out more in the front and taper back. Good for protecting against door dings in parking lots. Can be adjusted some. These are in about as far as they can be.
FULLSCALE
Adam
Ontario, Canada
Thank you sir! That's exactly what I was looking for, especially with the comment of them being in about as far as they will go.
I see the advantage in protecting from door dings but I think they'd still stick out further than I'd like. If it's not too much trouble, does it look like the brackets could be modified to bring them in even further?
I'm leaning more and more towards just making something on my own and having them coated in Line-X to get exactly what I want. I do appreciate the pictures though!
joeb427
Just in case you aren't aware, you can buy the RB20's with bed liner coating.
Description
RB20 Running Boards offer off road styling while also helping to protect vehicle finish while providing a wide, full-length step platform for easy entry to vehicle. Built from 16-gauge zinc coated steel and coated for corrosion resistance.
RB20 Running Boards (Protective Bedliner Coating)
a" data-cycle-timeout="0" style="font: inherit; border: 0px; vertical-align: baseline; position: relative;">
Product Details:
Application Notes: International Application
Construction: Galvanized Steel
Design: One piece
Finish: Protective Bedliner coating
Installation Notes: No drilling required
Product Notes: Includes mounting brackets
SideStep Style: Cab length
Title: Go Rhino - 69036880T - RB20 Running Boards (Protective Bedliner Coating)
Packaging: 92" x 13.5" x 9.5", 75.6 lbs
FULLSCALE
Adam
Ontario, Canada
Thanks Joe, I did see that earlier. For some reason the warehouse I can get them from through work only stocks the powdercoated ones and if I were to order in the bedliner ones they would be more money than getting the powdercoated ones Line-X'd. I like the idea of Line-X on them for the lifetime warranty due to the salted and brined roads here in Ontario.
