- First Name
- David
- Joined
- Jan 28, 2022
- Threads
- 11
- Messages
- 4,566
- Reaction score
- 23,251
- Location
- Portsmouth, NH
- Website
- subQuark.com
- Vehicle(s)
- Soupie! Race Red '22 XL 101A Scab 4X2 w/steelies
- Occupation
- game publisher
Not silly at all and I only learned of this last year.May be a silly question but...
I always hand wash Truck and wife's Subi using a quality car wash soap.
When you use a foam "gun" hose attachment, and spray your vehicles down, do you also have to/should you also use a mitt or cloth to "wash" it down and rinse ? Or does the foam solution basically clean and then you rinse ?
Never have used one before and I see many of you use one.
I don't let my Ranger and wife's Subi get "dirty dirty" just the usual road dirt from regular driving.
And, which one is good quality and recommended ???
I like the MJCC foam cannon but there are many good ones.
And I often just foam and rinse. No hand washing, no drying. It'll knock off the big dirt.
If I want to do a coat of graphene, then I'll foam it and use a few microfiber towels with a bucket of soapy water. I do use a bucket grate in it. Then rinse and try to dry. It's often pretty dry before I get to do it.
I use the compressor or leaf blower to dry it sometimes.
Then 303, which I was nervous about before my first use. But it's easy, just wear nitrile gloves if you don't want black and brittle finger nails.
Spray the 303 into a microfiber towel or sponge with the nozzle pressed right up to it. A little goes a long way and I'd guess I could do Soupie a dozen times with one bottle.
Just wipe it on a small area, like less than a panel (I split the bed side into 2 or 3 sections). Really thin coat that will be ready to buff in about 2 minutes. It "flashes" to white and buffs off easier than carnauba wax.
I only did two 303 coats last year with just foam and rinse in between. I also graphene the outside glass.
In my signature links I link to the foam cannon and also Mitt-on-a-Stick which I wouldn't buy again. It's too heavy but okay for the roof, hood, and tonneau cover.
I don't go nuts like Kate does and rarely detail the inside, except for the glass which I only do with water. A la IMJOSHV of YouTube fame. I sometimes pull out the front mats and blast them, but usually it's a shop vac and an attempt to get some of the Cheech hair!=D
Good luck and beware of the cost and time suck that becoming a fancy-pants Ranger owner can become!
