First improved thing about the 2022?
NickTheEnforcer
Anthony
Northern Illinois
I dont have a problem with the plastic push-pins on my '19 at this point. It takes a few minutes to properly remove them. I thought for sure a few would have broken by now. The only concern I would have with the zinc coated bolts is that after time both sides of the threads will rust out. I would probably coat with some white lith grease periodically. I'd much rather have seen the oil filter relocated to a better under hood spot.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Down the road I guess some type of metal threaded inserts would be the 'replacement' along with re-enforced grommets for the liner. Seems complicated.
Brad-Dallas
Brad
Irving, Texas
2021 Ford Ranger Tremor - Black
So glad you asked….
1. no rear folding headrest
2. no hood struts(as of 2022)
3. no PRNDS light
4. no glovebox damper
5. no RANGER embossed into the Lariat seats
6. no console (pen) cubby
7. no 12V outlet in the console without 110v option
8. no bright trim rings on the 12v covers that matched the radio knobs
9. only 4 bed tie downs instead of 6 (as of mid 2019??)
10. no engine cover
11. no owners manual cover
12. Eco badge on tailgate
13. no plugs in the rocker panels
14. no ignition bezel (has always been missing)
15. steel front fenders (aluminum before) estimated after March 2021 and all 2022
16. no bright button on parking brake
17. no color keyed tailgate handle on Lariat just black plastic without chrome pkg.
18. no aluminum spindles, they're now steel
19. rear passenger doors no longer have external touch lock
20. front seat headrest tilt adjustment
21. (2) 4.2" productivity screens instrument cluster replaced with (1) 4.2" screen in Lariat 500A
22. Floor Mat mounting tabs on passenger side
23. Small cubby inside glove compartment to hold owners manual.
Lariat Tremor makes up for most if not all these deletions ?
Living The Dream
I don't see them seeing much vibration or stress, so a few ft lbs is probably more than adequate.
I reinstalled them with just a tiny bit more force than when I removed, but being mindful not to crush the liner material. If I had to guess, the Ford tech that may end up doing it in the future will not be so gentle... :confused:
Ford Tech preferred tool for 10mm bolts.
Elmosaurus
Elmosaurus
Harveys Lake, PA
2022 Ford Ranger (SCrew Lariat Tremor)
I was worried given stories I’ve read, that the filter would be on stupid tight from the factory. But it was not horrible, and twisted off with a cap wrench without too much fuss.
