Engaged 4Hi while on highway
Slanger
2020 Ford Ranger
Hello everyone, this may sound pretty dumb but yesterday I let my mom drive my truck to take my brother to the airport and she told me she accidentally put it into 4hi while driving. I’m kind of worried she might messed the truck up. Today I took it out for a ride to see if I could notice anything wrong. While driving I heard what sounded like something fell off the truck. It was as if something metal hit the ground. Maybe I’m just hearing things. After that I kept driving and I heard a noise that sounded like brakes scratching as if the brakes were going out. Not like the high pitch noise, but like the grinding noise. Should I take it in to the dealership and see if anything broken?
Dhass68
Dan
Kelowna B.C.
2020 Ranger XLT
Brake and Suspension mechanic
I would think so
BigOlBish
2020 Ranger XLT FX4 Rapid Red
Check the front driveshaft. My buddy did that to his jeep liberty and we thought it was coming from the brakes too but the cv joint was grenaded
Slanger
2020 Ford Ranger
Will do. The truck drove smooth, but the noise did worry me.
BigOlBish
Yeah that's how his was. Not saying its going to be the same but he just went to a pick n pull and snagged a front drive shaft and it was fine after that. Obviously won't be as many ford rangers in scrapyards yet though.
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
Depending on what speed she was going, may indicate if that caused an issue..
The manual says this:
"Shifting Between 4WD System Modes
You can move the control between 2H to
4H at a stop or when driving up to 68 mph
(110 km/h). The information display may
display a message indicating a 4X4 shift
and the LED for the selected mode flashes.
Once the shift is complete, the LED light
for the selected mode remains illuminated."
It does not say what happens if you are OVER 68mph... does the system just not change modes?? or it will, with consequences. :question:
Obviously you are hearing a noise... best crawl under there and take a look.
RoadBoss
Travis
Lakewood, CO
www.TJAoutfitters.com
If it's not safe, the truck won't allow it to switch into 4wd.
Also, to the OP, I would say it's highly unlikely that anything got damaged from a trip on the highway in 4wd, unless you're running completely different sized tires all around and constantly making sharp turns, and in this case, the truck probably wouldn't even let it shift into 4wd.
My guess is it's paranoia making you hear things and suspect an issue.
If it were me, I'd just drive it a little longer and see if the noise continues or gets worse before going to the trouble of taking it to the dealer.
Adventure Ranger
Saskatchewan, Canada
2020 Ford Ranger Lariate Crew Cab FX4 Sport
Heavy Equipment / Truck shop Foreman
I shift into 4x4 while on the highway all the time, always have. Part of life during a Canadian Winter. We can drive a long way with a clear road, then come into heavy drifts and ice all over the road, I just disengage cruise and shift to 4x4. No problem. My Sport Trac worked the same way, sold it at 300,000KM without any problems.
Living The Dream
when i was a teen, my mom told my dad the car was making a small noise, he test drove it and confirmed the noise.
he crawled underneath to look and found the culprit....a garbage can she ran over. she drove long enough to grind half of it away.
Maybe look to see if your mom has a shopping cart, a tricycle, or maybe a homeless person wedged under the transfer case. Offer medical assistance if it's the latter.
moral of the story....its always worse than described to you.
Like the lady who came in complaining of a noise and vibration.
She ran over a mattress.
OP, you're likely fine, but if it is making a noise that concerns you take it to the dealer.
Just take a quick look yourself first.
Quick story from years ago.
My wife had a white company car.
We walk out one morning and there's a big smear of blue paint on the front bumper.
Me: "What did you do?"
Her, very defensively: "Why do you automatically assume that I did something? DId you ever think that maybe it wasn't my fault?"
Me: "OK, I'm sorry. What happened?"
Her: "I ran into the side of a Deputy Sheriff's car, but I didn't get a ticket so it obviously wasn't my fault"
