Driver seat mods?
bdurham
Brian
2020 Ford Ranger
Process Operator
Hey all, I've got a 2020 Ranger, absolutely love it. But since im a rather large fellow, getting in to the vehicle is a bit of a pain in the neck.....literally (I'm also an older guy so not nearly as flexible!) Also is there any mods to adding some length so the seat will slide back a bit further?
I've got a 98 Jeep TJ and they have "big boy" seat adapters that give another 2-4" of leg room, really comes in handy...
These are not power seats, just the factory standard.
Thanks
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Welcome to the forum. I don't know of a longer seat track from Ford. You may have to come up with a different bracket.
How tall are you?
Langwilliams
Langley
Lorain, Ohio
Look at the tracks to see if you could get some steel strips 2 or 3 inches long, drill a hole in each end, an space the stock tracks back.
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Like stated above, I would just make my own brackets, or modify the seat mount somehow. I’m sure it wouldn’t be hard.
Some sort of offset mounting brackets might be simple enough.
