Dashboard wire routing help.
SD4160
SD4160
Scott
NJ
2022 White Lariat FX4
Electrical test technician
I jut did the same a few weeks ago for a bunch of wires, but from the passenger side. It' very easy from the passenger side to run the wires, but you have the extra step of dropping or removing the glove box. I removed mine because it's only 2 slide pins that hold it in, and was easier to just get it out of the way. The worst part was reaching up to disconnect the damper, but I don't think 22's have it, so even easier. Oh, nd my passenger seat was also out, so I could lay down on the passenger floor to see what I was doing up there.
The first group of wires I sent a single 14G wire in the front right hole (my red arrow) and it has easy pass through above the dash vent, then it's wide open up there. You may need a grabby tool or hook of some sort to reach up and grab it, ten attach your other wires and fish them up.
The second set of wires I used springy, reachy, grabby, flexi-tool thingy, and sent it in the rear right side hole (yellow arrow) aiming it toward the back of the truck and to the passenger side. It fed in very easily and popped out beside the glove box. This one was even easier, didn't even need to lay down to see it hanging in the center area, to the left of the glove box opening. Attach wires and gently pull them up. One wire had a bulky end connection, so I wrapped that in tape to prevent it catching on any of the plastic edges.
You may be able to use the flexi tool on the driver' ides well, I haven't looked up there, but it's pretty easy to run the wires under the dash to the passenger side and up.
Looks great. Thanks for the advice.
LevittownFordParts.com
Gold Sponsor
Benny
New York
All Ford's
Kinda off topic, but isn't that where the Tremor auxiliary switches go? Anyone know if the switch panel can be bought separately, possibly w/ wiring? Didn't realize that panel was removable. I'm planning auxiliary lights and stuff in the future and I would really love an OEM setup.
Maybe Benny @LevittownFordParts.com has more info. ?
The panel and switches can be found here
https://parts.levittownfordparts.co...ranger-tremor-dash-switch-panel-hb3z2104338aa
I cannot confirm yet but I believe the harness is integrated into the IP harness and is not an overlay separate harness.
- Benny
12Bravo20
Missouri
2020 Ford Ranger XLT FX4
SigOris
Greenwood Maine
Retired DoD EE
I want to run the same route, but for a HAM radio head unit.
Do you have a remote head and if so, where did you mount the radio?
No, it was an ICOM external spkr
SD4160
SD4160
Scott
NJ
Ok, so I'll confirm going towards the glove box is the easier route. I had no luck going towards the driver side, at least not with my patience, or lack thereof.
Popped the glovebox down and saw might light from beneath immediately, had it fished down in about 15 seconds. Then past the other end through an easy opening right behind the A/C control panel towards the driver side.
Used this to snake my wire up and through.
Tapped a hole in my dash tray for the camera screen power plug, might go back with a grommet to clean it up
Happy with my end result up top. Still need to finish wiring to camera and power, and switch.
Thanks for all the input everyone.
donsmith
Don
Dallas, TX
2022 Ranger Lariat
Television cameraman and video editor
I'm looking to get some wires from the dashboard tray to somewhere below the steering wheel.
From here...
To anywhere here.
Is there a way to fish the wire down/up without have to remove any additional dash pieces?
I was taught to buy very long tie wraps. Non-conductive. Easily flexes around turns. I use my three-foot tie wraps to snake through my Goldwing bike and they work great.
