CV FABRICATION DP INSTALLATION
Phessor
Arizona
2019 Ford Ranger 4x4 XLT Crew Cab
What kind of gains can I expect with no tune?
Travis9935
Travis
The Midwest
2021 Ranger
You don't need a tune with a Downpipe... It's a speed density engine. At least that's what Livernois has told me numerous times. You will need a type of defouler for the downstream O2 sensor though so you won't get a cel due to the freer flowing cat.
Aonarch
Alec
North GA/ Montana
Can you please for the love of god make a catless version!
They stopped because the EPA cracked down hard on aftermarket companies.
There isn't really a such thing as "off-road use only" on a publicly facing ecomm site anymore.
Same goes for the diesel world with DPF deletes, they are dying out.
yamahaSHO
Greenwood, AR
www.jaztuning.com
22 Ranger, 23 Maverick, 04 S2000, 07 Sky RL
ECU Calibration - USAF Retired
Actually, a speed density system is more likely to lean out/richen up from increased/decreased VE. MAF cars are the ones that just read the air passing the hot wire sensor without accounting for the efficiency of the engine. SD also is affected by altitude and pressure at the tailpipe from the atmosphere, without proper baro comps.
Travis9935
Travis
The Midwest
2021 Ranger
Just saying what Livernois told me numerous times. They said there really isn't anything to adjust with exhaust mods. I've seen many posts of people not even having any sort of tune running them.
yamahaSHO
Greenwood, AR
www.jaztuning.com
30wtq without a tune?
The dyno's I found on a quick search showed results with a tune. That said, lots of low end torque, or a bit peak torque at low RPM need to be done a little more carefully. That's where you beat internals.
Travis9935
Travis
The Midwest
2021 Ranger
Again, Livernois said there really isn't any tuning you can do downstream. They're a tuning company I'll take their word for it. When people say it's tuned for it it was prob before epa cracked down. Aka they were able to shut off the rear cat cel from happening. Either way NOBODY can do anything related to tuning with a aftermarket cat anymore.
yamahaSHO
Greenwood, AR
www.jaztuning.com
I know what you said... And I am a tuner. Both Livernois and I tune SHO's and guess who out of the two has tuned the fastest SHO in the world. Not them. ;) I do have a bit of an idea in this area.
That said, I personally would not run any downpipe without a tune, especially if gains are as you claim.
Max
2022 ford ranger xl stx special edition fx2
Wind turbine tech
I was looking for a afe twisted steel dp but found theyr discontinued, i might have a shop fab me up a 3 inch downpipe.
A bit incorrect. There are hundreds of tuners that will tune for high flow cat. Just not the large national, remote tune/OTS tuners.
Find a local tuner with a dyno who works with HPTuners and you'll probably be in luck.
Travis9935
Travis
The Midwest
2021 Ranger
They
It's HIGHLY illegal! Nobody is going to risk paying that hefty fine.
They
Incorrect.
I can put you in touch with a few right now.
The EPA isn't worrying about little guys just yet.
