Bcm
kemwm38
Rochester, ny
2022 Ranger Lariat Avalanche
How is the bcm reset ?
Loweredon33s
Baltimore
2021 Ranger
Performance person
For what purpose? Bcm reset is a little vague. What are you trying to accomplish?
kemwm38
kemwm38
Rochester, ny
Drl wire was severed, then repaired.
kemwm38
kemwm38
Rochester, ny
Was too late last nite to do anything. Want to make sure how to do reset today. Would like to get it right first time
TJMarchand
Trevor
Medford, MA
Flash high beam 5 times, step on the brake 5 times, wait for the battery icon to flash. I can confirm this works, I had to reset the BCM after I had only one headlight working for some reason.
You are confusing the BMS reset with the BCM, completely different.
That is the Procedure for resetting the BMS (battery monitoring System) not the BCM (Body Control Module). Two co.pletely different things. Which is the OP trying to do? Clearing codes after fixing wire should be all that is needed.
kemwm38
kemwm38
Rochester, ny
After a little more research apparently it will have to go to a dealer for their "proprietary software " to reset.
HeatXfer
Nor Cal
Retired Pipefitter & commercial HVACR Tech
I've not done it, but other Ford forums recommend disconnecting both battery terminals and tapping them together to quickly bleed-off residual capacitance. That's supposed to reset the BCM and erase "trash" memory. Try AYOR
This one is getting some misinformation.
1. Use a Scanner or Forscan and clear the Code
2. To ensure that you have a valid confirmed splice fix and to confirm that the BCM was not fried and or the FET (Self Protection) of the BCM is not still enabled and disabling power output.
Perform a BCM (Self Test) via Scanner or Forscan
If the BCM self test faults that specific circuit again then check your repair but see below
The code reset would normally be all that is needed, but this has been this way for an extended period of time, and after enough events (fault counter) the system can permanently shut off power output on the specific circuit. (This requires a BCM Replacement) IF this has occured.
