NoCoRanger
OK, thanks - I'll try that.I found it easier to drop the skid plate and reach in from the inside. Only loose the rear bolts and remove the front ones. Then slide the plate out. Only requires one size socket too.
Its tight. ( a bit of a pain esp if you have large hands)
Removing the plastic air dams will help as well as turning the wheels full left/ right, to give you more room.
Reach in from under the bumper and locate the fog harness connector. Disconnect, then turn the fog lamp counter clockwise to remove.
Thanks, will try this also. ?
Yep - FX4, just drop the skid plate and easy access. I remember the first time I changed them I reached up without removing anything and ended up taking about 30min a side, had bloody knuckles, a very sore hand/wrist from trying to be a contortionist, and swore a lot. I even doubted I would be able to get the new builb in on the drivers side.I found it easier to drop the skid plate and reach in from the inside. Only loose the rear bolts and remove the front ones. Then slide the plate out. Only requires one size socket too.
