Alarm menu
Arron
Arron
Seattle, WA
2019 Ranger SuperCab Lariat FX4 Sport Magnetic
Software developer
According to our manuals there is an Alarms menu in Settings > Vehicle > Alarm. I was able to enable its display using the following forscan options.
IPC 720-02-02 Xxxx xxxx
0 - Alarm menu hidden (Default??)
4 - Show menu
Is this menu showing for anyone in their models without forscan?
Also I’m not sure if the options work as I have no idea how to test out the differences between the settings or what the setting differences are. The “Ask on exit” option does ask an annoying question of what setting you would like on exit of the vehicle. But the real settings I just don’t know how to confirm.
Akshon
San Diego, California
19 Ranger Lariat FX4 Crew Magnetic
Porpoise Hork
Bret
Houston
IT
This was not active for me and had to turn this on.
lawrench
Harry
2019 Ford Ranger Lariat SCrew FX4 Lightning Blue
Thank You, I did this mod today.
Hirnlego
SC
2019 Ford Ranger XLT 302A
Has any one added the shock sensor to a truck? Has any trucks come with them already equipped?
someguy
g
Colorado Springs, CO
2021 Ranger XLT FX 4x4
Occupied
I have installed the perimeter alarm (shock sensor) to a 21 XLT FX4. The device is enabled via ignition on/off, door open/close, brake pedal combination. The perimeter alarm does work but there is no Alarm menu.
At some point I'll attempt to enable the menu via Forscan.
06.12.2022 Menu enabled via Forscan v. 2.3.47 in the IPC module it's called Perimeter Alarm Guard Control
