Thanks. Looks better than what I thought. Kinda of like the beveled look on girlfriends XLT but that should work. I'm planning on going with aftermarket but do you know if the sync 3 8 inch will fit that bezel. I really do appreciate you post in the picture thanks.
You could just by the factory bezel if your going to use a sync 3 screenThanks. Looks better than what I thought. Kinda of like the beveled look on girlfriends XLT but that should work. I'm planning on going with aftermarket but do you know if the sync 3 8 inch will fit that bezel. I really do appreciate you post in the picture thanks.
I'm undecided at this point that's why the metra would be a good option if I could go either way. I actually did the sync upgrade from 4 to 8. I liked it but wasn't happy with the gray bezel or having the extra heated seats and rear defroster on control panel. The metra would allow me to retain my current control panel. I noticed the other fella said you could get the upper bezel and has a video with a part number but I'm not having any luck.I did send him a message hopefully he responds and if I can get the upper and black I'll probably just use that and still order the metra..hope that's all understandable I'm in the garage I own a repair shop. knee deep in Grease right now. Thanks againYou could just by the factory bezel if your going to use a sync 3 screen
Gwillie, Did you do install yourself? Does your factory back up camera work and if so do you have to do anything special? Which harness did you use? The axxess AXTC-FD2 says it doesnt incorporate the factory camera.
Youll need the ax-addcam-fd1 to retain backup cameraGwillie, Did you do install yourself? Does your factory back up camera work and if so do you have to do anything special? Which harness did you use? The axxess AXTC-FD2 says it doesnt incorporate the factory camera.
So you need both the axtc-fd2 and the ax-addcam-fd1 for a aftermarket install?Youll need the ax-addcam-fd1 to retain backup camera
Yes if you want to retain reverse cameraSo you need both the axtc-fd2 and the ax-addcam-fd1 for a aftermarket install?
Couldn’t get the camera working for the life of me. I had a pro installer helping and we couldn’t get it. After a few calls to metra the ac-addcam-fd1 is for adding camera to factory System not retaining it after a aftermarket install.Yes if you want to retain reverse camera
I was watching videos yesterday. Not sure if anyone has done this and can shed some light to which direction they went and parts used. Few ways to go about it part wise. Also for anyone else that swapped system for aftermarket did you use anything special for the usb? My radio has a standard usb connection not the micro. I have the alpine with the amp stacked on it so I need to find a right angle connection for it to fit.you can hardwire to the camera harness using an RCA and 6 volt step down. it is a common issue for cars that don't have a compatible harness
im glad it is finally out.idatalink showing Ranger as compatible now... time to take the plunge.
So does this mean that you're able to retain all of your factory options on the aftermarket stereo? Sorry new to the chat but this is my next upgrade to my Ranger.idatalink showing Ranger as compatible now... time to take the plunge.
