AeroForce Technology Interceptor
dozxab
Prescott AZ
I just set up my new Interceptor OBD2 gauge on my 2022 Ford Ranger. I have it set to display trans temp and boost. When I start the truck the display does not illuminate until I hit the 2 buttons. I contacted support and they told me to try non Ecoboost option. I replied to them that it did not work and there has been no reply. Anyone have one that has been through this?
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Remote start or not? My iDash does not turn on with remote start.
dozxab
dozxab
Prescott AZ
No. I've run into that problem before with another device. Just on normal startup with the key.
dozxab
dozxab
Prescott AZ
" 7. Connect switched 12v power (if necessary). The center pin of the 3-wire harness is for switched 12v power and is not required for virtually any CAN bus vehicle. "
It powers up normally after I press both buttons at once.
Colo_Ranger
Step 7 worked for me. I know it says it shouldn't be required but... it was for me.
dozxab
dozxab
Prescott AZ
Hmm...I will try that. Annoying to hit the buttons every time. Support was useless. Were did you get power from?
Colo_Ranger
Agreed - The only time I have to hit the buttons is if I use remote start. Even then, it will kick on after 5-8 minutes. Startled the snot out of me when I forgot.
dozxab
dozxab
Prescott AZ
Just wired it this morning. That did the trick. Thank you!
