Adding Rain Sense
daczone
2020 Ranger
This is a DIY for those interested in a bit of a hack or mod to add this option to your truck. Sharing with the group...
This is a AS-IS DIY project that you will do at your our risk.
I designed a quick 3D cover. You can print this yourself or have someone do it for you. Search for https://www.thingiverse.com/thing:5905369
I designed this to allow room for the sensor and pad. Note the FORD Sensor has gel already applied. If you have a lip on your sensor, you need gel as the sensor must sit FLAT against the windshield with no air bubbles. No lip, no gel. To install you will need to notch your camera cover behind your mirror to run the square piece into and run the wiring. (3 wires). How do I plan to keep the sensor on the windshield. A small amount of silicon should keep it in place.
You will need the Rain Sensor… Normally this attaches to the windshield in this mount (see below) which is clear glass. However vehicles without this option have the factory black FRIT covering the hole. FIRT is ceramic paint that is backed onto the windshield. It does NOT come off.
So here is my mod. Print a little 3d cover and hang the sensor to the right of the mirror/camera cover on the passenger side. This mod puts the rain sensor to the right of the mirror with the cover over it much like what comes factory on many vehicles. I used a 3 pin connector (slightly modified to fit) the factory plug from AMAZON (Search for 3 PIN LED CONNECTOR) and will find them. Sorry I don’t have the exact part number as I bought these a long time ago. You will need to trim the plastic as pin 1 of the connector has a notch in it. I used a razor blade and just did a 45 on that edge of the connector. Don’t force the connector into the sensor, it will slide on with little effort. There will be no tang to hold the connector in place, but you can wrap it with a piece of electrical tape or heat shrink if you are concerned about it coming loose. Mine is snug and stays in place.
Rain Sensor wiring:
What the complete circuit looks like:
Pretty straight forward. The Sensor goes to switched 12v, Ground and Rain Sense. Problem the connector C903 (Drivers side A Pillar) on my truck has nothing in Pin 11 (Yep Ford saving money). So we need to keep on tracing that wire…. Rain Sense goes to 81-2 D / 81-2 C (Wiring Diagram)
Which connects to Pin 4 @ Connector C125 (At the Wiper Motor) Yellow wire for my 2020 Ranger or Pin 2 @ Connector C226 (The SCCM module located under the steering wheel) Also a Yellow wire for my 2020 Ranger. 3 bolts to remove the bottom of the steering console. And tap that wire. I like to solder my connections. So here it is:
Connector unplugged​
Yellow wire going to the connector @ PIN 2
While you are here grab switched power and ground @ the fuse block. (MAKE SURE to use SWITCHED POWER), And always use a fuse. I used a fuse tap I had on hand.
Wires ran. These run under the headliner and down the drivers side A pillar.
You will notch your camera cover (behind the mirror) something like this. I used a dremel which made quick work of it, but a file or hacksaw would probably work. Use your 3D printer cover as a template.
Which will then look something like this. You can put a little bit of black RTV to keep it attached and hide the 2 pieces.
It should fit into the slot and will look something like this. The sensor will be mounted to the windshield under the cover.
Not sure if this is required but I also replaced my WiperSwitch for the one that includes AUTO on the stalk. The part number is kb3z17a553a
I printed my cover with Carbon Fiber Filament and white letting on top for vanity..
Feel free to make any corrections to this project. Happy Hacking!
npspears
Nathan
Ranger XLT
Thanks for writing this up. Bookmarked for the future.
Cheers!
daczone
daczone
2020 Ranger
Rain Sense.....
Rain....
and...
Not Rain....
Very easy to determine which you are in....no sensor needed.....:crackup::crackup::crackup:
I get it... It's not for everybody, But I live in the rainy state of Oregon and all my other cars have this feature and I personally love it. IMO it's kinda like Adaptive Cruise, you don't realize how nice of a feature it is until you've used it. I hear people say sure my car has cruise, But go on a long trip with adaptive cruise and you will love it. Same for Rain Sense, spend a raining week in Oregon and you will love it.
Dave, just making a funny HaHa....not meant to criticize your mod.
Info...I have a Lariat with the rain sensor and it does come in handy !!!
daczone
daczone
2020 Ranger
Todd Chapin
Todd
Alexandria
2019 crewcab lariat fx4
Chef
Nice write up bit allot easier to check the box at the dealership for tech package?
daczone
daczone
2020 Ranger
Wish I had that option... but then again my truck as a loss leader, so it was what it was. But I only paid $32k out the door. I did replace my windshield in 2022, had I known I would have gotten the Rain Sensor windshield.
maxbottomtime
NE OH
2021 Ranger XLT SCAB 4x4
I can respect that. Straight shooter.
Dave859
Lexington, Kentucky
2022 Ranger Tremor
Manufacturing
Great write up. My Ranger has this option from the factory and TBH it doesn't work all that well.
daczone
daczone
2020 Ranger
I'll find out this next year... For me it's not so much turning them on as it is turning them off. When your passengers say.... "Are you gonna turn those off?" you know you may need this mod.
