adaptation sensors front ranger 2023
Raf
Rafał
Poland-Katowice
Ford Ranger VI 2023 R
Na wyświetlaczu widać przód i tył, ale nie ma grafiki
As far as you not seeing the (PAM) on the loaded modules via Forscan
Since this is a 6G version Ranger and is also SYNC 4, this appears to be completely different than the 5G version Ranger.
1. Try loading the Forscan scan (load) as a NEW PROFILE, this will force a full scan of the modules to load. This may bring the PAM module into view with Forscan.
It may also be the adapter you have, the OBD-Link EX is the preferred adapter.
2. The only way to confirm what modules the truck has is to use the As-Built data base
Type in your VIN# and download the As-Built files for your truck
Repeat the same (using) a like truck with the Front Park Assist and or Sensors, as I am thinking you may have the full-on parking assist (where it parks itself) we do not have that on the 5g version trucks.
I recommend doing this to CONFIRM you even have a PAM module, they may have the PAM Intergrated with the APIM or BCM with the SYNC 4 trucks. (IDK)
Save both downloads as a PDF file then print them out:
Go line by line and (side by side) compare each line and (HIGHLIGHT) every line that is different (does not match)
A quick way to do this (only look at the last 2) Hex characters of each line - This is the Checksum of the line (if these are different then something on the line is different)
Index - FordServiceInfo.Com
Note all lines that differ then use the link below to dive deep into what the hex-line is and what the data line represents
AsBuilt Databases - CyanLabs
CAUTION: using this site - it is ad based, DO NOT click on any (OPEN) or (DOWNLOAD) tabs
this will download a web browser adware add ons.
Just click (CLOSE) or the (X) to close it out and the database will open up.
I made the mistake of clicking open (1-Time) and spent hours trying to remove all the adware.
I wish I could help more, but we in the US cannot access the manuals for your truck so we can only offer guidance using the 5g manuals and US version specs.
Raf
Rafał
Poland-Katowice
You gave me valuable tips. I will try. Many thanks
Raf
Rafał
Poland-Katowice
I downloaded files from another car with a sensor, made changes, nothing changed. I connected other systems, the front parking sensors show errors. There is no Pam in this car, I checked 4 cars by VIN on the Ford website and none of them have Pam. The changes in the parking system are Apim 7D0.............. It is the same, regardless of whether the harness is connected or disconnected, I need to locate the parking module in this car, where is it? are the plugs connected, cables to the parking module I will run from the module to the front of the plug in the bumper. But where is this module because there is no module under the seats.
RangerBill
In North American Rangers the PAM module is built into the BCM module. Try looking in the BCM for PAM settings.
I did some digging and using the 24 (US-Version) 6g.
The PAM is NOT installed (IF) you have the 360 Deg Camera it solely uses the IPMA
If you do not have the 360 Deg Camera, it uses the PAM (Module) and is installed.
So, I am somewhat confused and may help me understand your issue.
What level of features you have and what level of features you are missing and want to add?
Are you trying to add - Parking Sensors (Only) or Parking Assist & Parking Sensors?
Parking assist adds 4 more parking assist sensors in addition to the parking sensors.
So, parking sensors - total of 8 (4 Ft & 4 Rear) + 4 parking assist sensors (2 Ft & 2 Rear)
Depending on what feature you are going for here, we need to determine what setting needs changed or what power issue is missing.
For example - have you tried looking in the BCMC module in the (Quick Menu) and checking for anything to do with (Parking Sensors)
The BCMC is an additional module the 5G does not have.
Another example is - you added the switch to the switch pack, but is the connector wired for that switch input/output?
Raf
Rafał
Poland-Katowice
I'm only adding 4 sensors in the front. There will be 8 in total. 4 front 4 back
