9005 High Beam LED Blubs for 2019-2021 Ford Ranger
AUXITO
Diamond Sponsor
AUXITO
AUXITO Senior Manager
Eric installed 9005 LED bulbs from Auxito on his 2019 Ford Ranger.
Thanks for watching guys!
Eric's Channel @TheWiscoGuyz
Product Links ? AUXITO Y13 Series 9005LED High Beam Bulbs
15% OFF with code VIP15
Brief Introduction
  • Run-on DC 12V-24V, 40W and 8,000lm per bulb, 6500k white
  • Please note they can not be used as DRL, they may have flicker or can't turn on the issue due to the low voltage of DRL. Please ensure you turn the DRL function off and ONLY turn the high beam function on
  • Same Beam Pattern Like Stock One: 0.079in the ultra-thin copper board for 360° illumination
  • Mini Sized Lamp Body: no more modification on headlight housing or cover
  • Can-bus Ready Design: an upgraded driver with built-in intelligent IC and temperature control ensures lamps work at the best status without error or radio interference
  • Efficient Cooling System: The whole aviation aluminum body and 12,000RPM cooling fan provide supercooling ability, which ensures a longer-lasting up to 50,000 hours
Check out the link to AUXITO on some bulbs for your Vehicle!
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
I have a set of these for high beams. Amazing for those empty roads. Who needs off road lights with these.
AUXITO
AUXITO
Diamond Sponsor
AUXITO
Agreed, led lights are enough to make daily driving better.
