Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
Morimoto's New Ranger XB LED Headlights are now live on our website.
2019-2021 Ford Ranger Morimoto XB LED Headlights LF437
Morimoto XB Headlight Features:
If you are interested in more visibility while giving your truck a more aggressive look, then these Morimoto XB Headlights are for you. With a wider field of view and brighter beam, these headlights are an immediate upgrade over stock options. Using triple-projector optics, all start up action is sequential. That means when the Daytime Running Lights, powered by OSRAM 5000K LEDS, turn on the projectors will illuminate in a two-stage sequence. These are the only set of headlights in the Morimoto XB lineup that used three Bi-LED projectors, three low and three high beam, to light up your roads and trails. For more traditional operators, the projectors can be set up to run without the sequential startup. High-Quality Construction with Plug-and-Play Install
These Morimoto XB Headlights offer a plug and play install for an instant upgrade to the grill of your Ranger. Installation of these headlights just involves utilizing the specialized wiring harness that comes with the headlights. This product is made light weight, with durable ABS plastic housing. The outer lenses of each headlight are made from UV-coated poly-carbonate that helps keep the lenses looking clear. LEDs color temperature is 6500K which creates a bright white look.
Fitment:
Note: These housing have been designed for, and tested on US-spec vehicles. Other countries' compatibility may vary and is not guaranteed.
- Unique look with improved lighting output
- Made with high quality materials
- Easy Install with plug and play wiring
- Includes plug 'n' play harness, fuse tap, DRL modules
- Backed by a 5-year warranty
- Black Housing with built-in heat sink
Fitment:
- 2019-2021 Ford Ranger
