2019-2021 Ford Ranger AlphaRex LUXX Series Alpha Black LED Headlights 880121
Status
Not open for further replies.
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
In stock and on sale for anyone in the market!
Highlights:
  • Plug-n-play direct replacement
  • Patented signature 3D ice-cube projector lens
  • Switchback white LED DRL and amber LED sequential turn signal,
  • Polypropylene Black housing and polycarbonate plastic lens
  • Dual coated lens with anti-fog agent and preventative yellowing and oxidation coating
  • SAE and DOT Compliant
The LED Headlight Upgrade You've Been Searching For
AlphaRex has a solid track record when it comes to aftermarket lighting. These LUXX-series are a bolt-on replacement for your factory halogen set up, a true plug-n-play set up there is no need wire, splice, or purchase additional looms for this LED upgrade. The functionality and look of these lights are the perfect upgrade for your Ford Ranger. The Ford Ranger LUXX-series projector headlights are composed of our patented rectangular projector lens, and the projection cut-off line is perfect for American LHD regulation. These headlights come with switchback white LED DRL and amber LED sequential turn signal, with activation light feature, which is a running light when you unlock your Ranger. The outer projector is for low beam, while the inner projector is for high beam. In addition, the projectors are high/low beam projectors that are using LED chips. High-Quality LED Lighting
The Ford Ranger LUXX-series projector headlights are composed of our patented rectangular projector lens, and the projection cut-off line is perfect for American LHD regulation. The Ford Ranger LUXX-series projector headlights have a Polypropylene Alpha Black housing and crystal clear lens to give your truck a sporty look and makes it easy to match the lights with any color truck and front grill. The Alpha Black housing is specially designed with a glossy look mixed with black paint and smoke DRL lens to give your truck an all-black sporty and luxury look at the same time. The LUXX-series projector headlight lens are made from strong polycarbonate plastic and also have a layer of anti-fog agent on the lens for optimal light output in extreme climates and another coating to protect the lens against yellowing and oxidation.
The Ford Ranger LUXX-series projector headlights are compliant with SAE and DOT FMVSS108 regulations, and are certified to ISO-9000, ISO-9001 and ISO-9002. Since the headlights have a DRL feature you will need to apply the DRL module included in the headlight kit. No modifications are required for installing these headlights since they are plug-n-play direct replacement for your truck. The AlphaRex headlights are easily removable when you need to return or sell your truck and it will not void your factory warranty.
Specs:
  • Fitment: 2016-2021 Ford Ranger
  • Lens Color: Clear Lens
  • Light Feature: Activation Light, Switchback DRL and Sequential Signal (Light Tube)
  • Feature Color: White DRL, Amber Signal
  • Light Source: Built-in AlphaRex Luxx LED
  • Low Beam: AlphaRex Luxx LED
  • High Beam: AlphaRex Luxx LED
Stage3Motorsports
Stage3Motorsports
Joel
Phoenix Arizona
Sales Specialist
Six sets in stock, use code S3M50 to save an additional $50 through the end of the month.
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
These are amazing. They are truly better even than the AlphaRex Pros with drop in LEDs, especially the high beam which seem to go out further than the LED equipped Pros (I have had both). If you don't like the startup "light show" you can easily swap the bottom modules with ones from the Pros, if you can get some modules from some Pros, that's on you.
Publius
Tampa, Florida
'22 Ford Ranger XLT (Forged Green FX4)
Attorney
Is there any other way to do that; someone mentioned not connecting one of the wires to ignition. These lights look great, but the show is a little silly to have every time you start or turn on lights (not quite sure when/how it goes on).
Status
