325's, true 35's?
Jms81661
Las Vegas, NV
2020 XLT Ranger Sport
Truck Driver
325's are clearly closer to the ultimate 35.
Anyone running 325's. Is anyone running 35's on stock rims?
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
As far as I am aware nobody makes a 325/70R17 so although on paper it may be a better choice its not an available one. I always point people to tiresize.com for people to reference tire sizes but i also follow it up with "not ever size is an available one"
Jms81661
Las Vegas, NV
Truck Driver
So then a 315 is the closest to a true 35"?
Jms81661
Las Vegas, NV
Truck Driver
On top of not being a real size, some 285 width tires fit on stock wheels, but not all. a 315 (which is a real width) is 30mm wider and most definitely would not clear the spindle.
How do you get to a 35" then. 315's are barely over 34"?
Gr8Hortoni
Subaru, int in a 5G
Trucking
34.4x12.50 actually. Closer to 34 than 35 but not by much. Unless you’re lifting, have some serious offset and delete crash bars, I think you’ll have a hard time clearing them. I’ve been looking hard at 285/75 (33.8”x11.2”) for my tremor when I get and I think I’ll have a hard time with that without going crazy on the lift. Why not just go with 35-12.5-17, which is a true readily available size if you’re that set on it?
Gr8Hortoni
Subaru, int in a 5G
Trucking
57 different styles available according to tire size.com
Jms81661
Las Vegas, NV
Truck Driver
Cuz I need every in inch I can get, these 33's are making me turn around too much on the trails. I already have the 3 1/2". 2 more inches , or as close to that as I can get, will help demonstrably.
Colo_Ranger
Someone said it above, but if you're looking for a true 35 you'd have to go with a 35x12.50r17. Ultimately a 35x12.50r17 and a 315/70r17 have a total height difference of .6", so .3" on each side of your rim. It's not that much, but if you want a true 35 inches, you'd have to go with a 35" tire. (though, not all 35 are truly 35")
