Stage3Motorsports
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 894
- Reaction score
- 1,367
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
Here's an Inexpensive mounting solution to mount your favorite lights on your Ranger!
2019-2022 Ford Ranger Grimm Off-Road Hood Hinge Light Brackets 10159
2019-2022 Ranger Grimm Off-Road Hood Hinge Light Brackets Features:
You want to add some extra LED lighting to your 2019-2022 Ford Ranger build, but you are not sure what space you have left on the exterior to mount it. Maybe on roof rack, front bumper, or above the windshield? How about right on the hood hinges in the lower a-pillar/cowl location with the 2019-2022 Ranger Grimm Off-Road Hood Hinge Light Brackets. You can add premium a-pillar LED lighting from top brands like Baja Designs, RIGID, Diode Dynamics, and many more with a simple bolt-on installation. This position allows the additional lighting to flow perfectly with the rest of your off-road build while adding a bit more toughness and complexity to the exterior. For the pitch black nights when you are navigating through boondocks, having more light output to supplement with the headlight output is crucial to being aware of your surroundings and keeping yourself safe. After all, you want to make it back home in one piece to be able to plan your next off-road adventure.
Compatible with 3" LED Pod Lights or Smaller
The 2019-2022 Ranger Grimm Off-Road Hood Hinge Light Brackets conveniently use the stock mounting points for installation. Beyond the simple bolt-on installation, there is no additional cutting, drilling, or any other modifications that need to be made to complete the installation. Each hood hinge bracket is compatible with up to a 3" LED pod light which gives you tons of options when it comes to beam pattern, light output, light color, and brand. Why choose this mount? The high-strength steel construction is hard to damage, even for the clumsiest of us. If that was not enough, each bracket is finished with a black semi-gloss powder-coat that protects against corrosion. You might be worrying that you will be welcoming a new annoying whistling sound by having something like this on your hood hinges, but the low-profile design fits tight to the hood hinges to not allow air to flow underneath with a precise fitting using laser cutting and CNC machining. This completely eliminates any potential disruptive sounds and makes incorporating new LED lighting as seamless as possible.
Fitment: 2019-2022 Ford Ranger
- Mounts an auxiliary light in the lower A-pillar/cowl location on each side of the vehicle
- Compatible with lights up to 3 inch diameter
- Laser Cut and CNC formed from 7ga high-strength steel
- Black Semi-Gloss Powder Coat Finish
- No increase in wind noise or whistling
- Made in the USA
- Limited Lifetime Warranty
